As the title says, the PSU doesn't boot the system. It only does after CMOS is cleared each time. I tried with a different PSU it worked okay.
The PSU had apparent leakage from the base of a pair of caps. I replaced them with new ones, yet the same issue persists. It shows voltages on the 12 volts at 11.5 v etc. All of the voltages are alright as per the link below.
http://pinouts.ru/Power/atxpower_pinout.shtml
What might be the cause I wonder.
As to the 'leakage', there are no physical issues with the caps, like bulge or the rubber coming out at the base - only the brown vinyl glue like residue at their base which was not there at the same caps in the PSU which worked to boot normally.
What tests might I carry out on the PSU to identify the cause?
The PSU is an ATX 250Watt PSU.
