Capacitor question
  • jmdeathsquad
    • Mar 2006
    • 11
    Capacitor question
    hi all, this may have been asked/answered before but I couldnt find the answer, can I replace caps with a lower farad value but a higher voltage rating? I'm not sure if it's safe or if anyone has tried already. I ran out of caps of the right size and I only have higher voltage with lower farad value caps left.
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Capacitor question
    it is better than a lower farad rating and same voltage. YMMV though. what is the difference in farad rating?
    try not to decrease too much because it may affect stability, capacitance on boards is usually minimal anyway.
    • jmdeathsquad
      • Mar 2006
      • 11
      well i have like 100uf at 25 volts or so... I wasnt going to try it because it seems a little low. How much would be safe to decrease the capacitance? these would replace 1000uf at 6.3 volts
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        that seems far too low, i have seen on boards 470uf 16v and 330uf 25v used in places where 1000uf 6.3v would normally be used.
        it depends where it is used really, on input caps and vcore i would not recommend to decrease the capacitance much, depends really if you are using one of the more powerful processors for the board design or a low power one. in the case of not having the right caps if you have a row of caps in parallel you could double the capacitance and use half the number of caps for instance, populating every other position. that would be the same result as long as the total capacitance is the same for that row.
        on other positions of the board you might be luckier and able to use a lower value but 100uf is really low and best to forget it do the job properly.
        • jmdeathsquad
          • Mar 2006
          • 11
          cool thanks for the info. I'll have to double check the board position when I get home. They arent on the input caps or vcore caps. I replaced the vcore caps with ones I had of the same rating and the input caps were good still (panasonics). The proc is actually a mobile celeron, but I was planning on increasing the voltage on it.
          • chth96
            Is it no harm to replace with capacitor without ripple current rating?
            by chth96
            When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
            Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
            But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
            Rubycon YK DataSheet (b...
            04-19-2024, 05:19 AM
          • MORETTIGIAN
            Capacitor detached from PCB – RTX 2070 Super Founders Edition
            by MORETTIGIAN
            Title:
            Description:
            During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
            I did not notice it detaching, so I am unsure of its original location on the PCB.
            Procedure performed:
            - Removed backplate
            - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
            - Reapplied thermal compound
            - Reassembled card
            Observed behavior after reassembly:
            - GPU powers on and operates normally under...
            09-18-2025, 12:14 PM
          • quickname
            Cyberpower 1500AVR UPS repair
            by quickname
            I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
            Like clockwork, I've had to replace the SLA batteries every 4 years. It was about that time and the UPS was acting like it needed new batteries... randomly shutting off with AC present, not being able to charge fully, and poor runtime when AC was removed. So, I replaced the batteries but noticed that it was not charging properly.
            I decided to verify that the batteries were...
            11-12-2023, 09:57 AM
          • Prolog
            RTX 3080 FE Identifying capacitor
            by Prolog
            Hi people, I hope this is the correct spot to post this, I'm new to the forum.
            I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
            I hope these photos make it clear which component I am referring to:
            (yes, the soldering is a bit botched from removing the blown one, I know)
            I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
            12-01-2024, 08:27 PM
          • Bugmanscj
            Audio Linear Power Supply (LPS)
            by Bugmanscj
            Hi: Found this forum fumbling over the net looking for replacement capacitors for a high quality 2uv ripple model Kaia, Core Audio Technology LPS. I bought it used on fleabay and figured I would have to recap and sure enough one of the 22,000uf 35V 105c caps is bulging. These supplies were made briefly around 2014 for MAC Mini audio servers, and were quite costly at the time ($1.7k), you know it's audio... I will use it for a video processor power supply to replace a switched version. I figure it's a low cost attempt to see/hear what difference it might make in my system. Plus I get to learn...
            02-17-2025, 08:50 AM
