I have a Jetway Versa J7F4K1G2E motherboard. It has mostly polymer capacitors, but there are also some 220uF and 100uF CapXon electrolytic capacitors on it. They are in one of the coolest areas of the motherboard (it stays about room temperature there) and seem to be on the +5V, +3.3V, and +5VSB rails. I also have a high quality PSU. I was wondering if I should be worried about these capacitors failing.
Should I be worried?
Re: Should I be worried?
If it gets erratic replace them.
.Mann-Made Global Warming.
- Dr Seuss
The reason I ask is because Jetway has often used GSC/Evercon/Sacon capacitors in the past (and I wouldn't be surprised if they still do). These 3 brands (or rather 1 really) have been known to fail consistently.
Sacon capacitors in particular have a specific series - the FZ - that are known for their "polymer" looks. In fact, they are just regular eletrolytics caps (and very bad ones at that). If you see a vent on your "polymer" capacitors and the letters "FZ" printed on top, then you have Sacon FZ. Those should be replaced on sight.Comment
Agree.
Jetway likes FZ.
BTW: FZ come marked with either blue or black ink.
Printing and sleeves are just marking methods.
Neither one tells you if a cap is polymer or lytic.
They both come marked both ways.
- Dr Seuss
They don't have any vents. Some are marked "FP 98Ab 122 04" and others say "FP 99Ae 471 6.3". The ink is red.
Here are the possibly polymer capacitors:
(the larger ones are "98Ab" and the smaller ones are "99Ae".
And here are the CapXons:
The FP is the -logo- for FPCAP brand which are Functional Polymers.
Used to be owned by Fujitsu, now owned by Nichicon.
Good caps. - Leave them alone.
The 122 04 = 1200uF 4v
The 471 6.3 = 470uF 6.3v
FZ are a series of Sacon. I don't see any.
When I said "If it gets erratic replace them" I was talking about the small Capxon.
To modify that: If they are 6mm or larger I might replace them anyway.
[Particularly if any are near the chipset.]
.Last edited by PCBONEZ; 12-29-2011, 07:53 AM.Mann-Made Global Warming.
- Dr Seuss
The Capxons in the last picture are most likely used by the integrated sound card and network card... if you get crackling in the sound or the network disconnects often or has poor performance, maybe capacitors would be the cause.
Otherwise, I don't see them under enough stress to have issues so I don't think you should change them.Comment
It is nice to hear that the ones near the heatsink are polymers. However, the sound hisses quite a bit, but it did that right out of the box. Also, I have another device that has capacitors marked "B1 47 25V" and "47 VFK. 1W5". Are these good caps?Comment
For most of those Panasonic FC should be enough.
Check the specs to be sure.
Will have to be a bit better photos than those first two.
- Dr Seuss
by dragon3xHi, I have some 32 bits computer motherboards that need repair, as they fail to
power on.
Here are some examples :
switching supply area).
than 6.3 V.)
3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA... -
by slybundahey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
it has inside:
2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
2 x 470uf 16v LZ105c branded as G.Luxon
not heard of these brands are they any good?
iv attached photos of the charger and the board inside for an idea on the type of...-
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... -
by CamaHello,
I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
My model is : EASUN SMH-II 7 KW
Mother Board : P/N 18947-002401250250
Maybe the EASUN SMH-II 4.2 KW have the same capacitors
Thank you... -
by Ady2017I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
- Loading...
