stocking capacitors,panny fm
  • multimeter
    • Jan 2011
    • 739
    • united kingdom
    im looking to stock panasonic fm caps,as id like to stick with one brand,these caps are good in ripple ,low esr etc,is there any reason apart from the actual pysical size of these caps they cant be used in lcd tv power supplys,and main av boards,inverters etc?thanx!
    fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
    please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
  • Rob Northen
    • Jan 2010
    • 137
    • Denmark
    Re: stocking capacitors,panny fm
    Yes, if specs don't match
    • smason
      • 1652
      Many of us in the Monitor forum use them exclusively.
      I did just that, filled my parts bin with all the usual values in FM, and a few FC as many of the FC are shorter physically.
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Be careful with FC.
        They are good caps but their ratings aren't up to what a lot of the caps used in screens are.
        Choose replacement caps by the Ripple and ESR. <- Important.
        FM are usually good enough for what is found in screens but there are times you'll need something with better specs or physically smaller.
        FM run a little large for their uF in some sizes so to keep the Ripple and ESR where it should be you have to go to a smaller can in a better grade.
        For example I'm working with one now where none of the caps can be taller than 20mm.
        The otherwise appropriate FM are too tall.
        Mann-Made Global Warming.
        - Dr Seuss
        • DynaxSC
          by DynaxSC
          06-14-2024, 03:49 PM
        • chth96
          Is it no harm to replace with capacitor without ripple current rating?
          by chth96
          When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
          Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
          But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
          Rubycon YK DataSheet (b...
          04-19-2024, 05:19 AM
        • Antonynl
          What are typical ripple voltages on a laptop motherboard?
          by Antonynl
          I have here a HP pavilion hp 15-cs2975nd with a 1.095v power supply that is driven by a FDMF3035. I do see about 80mV of ripple on my scope. I searched through the datasheet to find possible values of the ripple but I don't understand the datasheet well enough.
          So I have two questions:
          1) what is the typical ripple voltages of gpu/cpu on a laptop or pc mobo?
          2) what would be the max ripple of a FDMF3035 that drives an output of 1.095V?
          Would be nice to have a rule of thumb of say a percentage of the supply voltage to be an acceptable ripple voltage....
          12-09-2022, 06:51 AM
        • Antonynl
          Lenovo 530 Vcore : what is the maximum ripple?
          by Antonynl
          Hi
          I have a Lenovo 530 14ikb i5 8th gen motherboard and it fails to start Windows: it normally dies after I try to load Windows. Getting into bios screen works fine.
          Made some measurements and I suspect that there is to much ripple on the 2 Vcore coils.
          What is normally the maximum ripple allowed on say any of the power supplies? A few %??
          The ripple is on both Vcore as outlined in red in attached photos.
          Could be a bad driver?
          Cheers...
          04-29-2023, 04:59 AM
        • piernov
          Core 2 "gaming" build with SLI
          by piernov
          My turn to post a build I guess, wasted way too much time on this one…
          First proper SLI board I get so wanted to play around a little bit since I got a couple 8800 GTS.
          Everything done with random parts I had lying around.
          Specs :
          • CPU: Core 2 Quad Q9450
          • RAM: 2x2GB KHX6400D2K2
          • GPUs: 2x Nvidia GeForce 8800 GTS G80 320MB
          • MB: P5N-E SLI
          • PSU: Antec Basiq Power 550 Plus
          • HDD: Hitachi Ultrastar A7K2000 1TB
          • ODDs: DVD ROM, DVD RW
          • Case: not sure
          Cooling:
          • 92mm rear fan
          • 120mm front fan
          • Additional heatsink on southbridge
          05-20-2023, 11:38 AM
