Capacitors for ESC
  • tarrigo
    • May 2011
    • 6
    Capacitors for ESC
    I fried two capacitors in an Electronic Speed Control and I although I found an exact match at Mouser.com they are backordered for about 17 weeks. I just need two.
    I am wondering if it is possible to use an equivalent or something maybe rated different that still might work. The capacitor I am wanting to replace is Radial and the specs on it are:
    35V 560uf
    105 degrees celsius
  • mariushm
    • May 2011
    • 3799
    Re: Capacitors for ESC
    It would help if you say where you live.
    If you're in US, a good online store to buy from is http://digikey.com.
    If you're in Europe, a good online store to buy from is http://uk.farnell.com (they have several languages and versions for various countries, check what works best for you).
    Besides those three characteristics, when you replace a capacitor with another one, you also need be careful of two other values that are not listed on the capacitors but are listed in the datasheets.
    ripple - the replacement capacitor must have equal or higher ripple value
    impedance - the replacement capacitor must have equal or lower ripple value
    If you can't find the datasheet for the old capacitors, it's generally OK to go with capacitors known for their high quality such as Panasonic FM or FR series, United Chemi Con KZE series, Nichicon HM or HN series and so on.
    If you tell us everything written on the capacitors you have, maybe we can suggest alternative capacitors.
    PS. There's also this site's online store but depending where you live, it may cost too much to have them shipped to you.
    • tarrigo
      • May 2011
      • 6
      I am in the US. It is a Rubycon capacitor. It has a number on it as well. T1017 and the other has the number T1020.
      • mariushm
        • May 2011
        • 3799
        That is probably the manufacturing date ... year 2010, week 17, respectively 20.
        These will work, provided they're small enough to fit the room you have on the board:
        10 mm wide:
        http://search.digikey.com/scripts/Dk...name=P12416-ND
        http://search.digikey.com/scripts/Dk...name=P14442-ND (the one above is better but this one is only 20mm high, great if you need low height)
        http://search.digikey.com/scripts/Dk...me=565-1695-ND
        12.5mm wide:
        http://search.digikey.com/scripts/Dk...name=P12401-ND (it's 50v but doesn't matter, as long as it's >=35v it's ok)
        http://search.digikey.com/scripts/Dk...name=P14462-ND (same story)
        http://search.digikey.com/scripts/Dk...me=565-1713-ND (same story)
        • tarrigo
          • May 2011
          • 6
          Thanks that information is really helpful. I have a fair amount of room to work with. I just hope some new capacitors solve the problem. I will let you know for sure.
          Thanks again.
          Anthony
          • tarrigo
            • May 2011
            • 6
            I guess I cant help but ask, is it ok if the microferete or th uf is above 560? I might be able to get something like this at Radioshack. Although I am not sure what the ripple current is on Radioshack stuff since it does often print that on the bags.
              master hoarder
              • May 2008
              • 12164
              You're better off not getting any capacitors from Radio Shack because they are general purpose and aren't suitable for your application.
              You need to specify what series your original Rubycon capacitors are. There should be a 2 or 3 -letter code on each cap indicating that. You can then use that info to find a data sheet for the cap in order to determine the ESR and ripple current rating.
              • dragon3x
                by dragon3x
                power on.
                Here are some examples :
                switching supply area).
                than 6.3 V.)
                03-21-2025, 02:46 PM
              • samoelec
                Trying to understand how to find best replacement cap for old parts.
                by samoelec
                Disclaimer: This is the first time I step into the realm of analog electronics and my natural language is not English, so please forgive me if I failed to use the correct terms when describing things.
                Recently I purchased a Tektronix TDS1012, a 20 years old product for cheap and I thought it could be a nice opportunity for playing (i.e. recapping) and learn something in the process.
                The power supply board is exactly the same from this post so I'll just steal it for now.
                I'm trying to find replacements for all those Lelon electrolytic caps, but then quickly...
                04-01-2024, 03:39 AM
                After all of...
                07-13-2024, 08:14 PM
              • chth96
                Is it no harm to replace with capacitor without ripple current rating?
                by chth96
                When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                Rubycon YK DataSheet (b...
                04-19-2024, 05:19 AM
              • Ady2017
                Are there any datasheets available for Elna RJG capacitors?
                by Ady2017
                I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
                05-25-2025, 02:19 PM
