Replacing capacitors with higher voltage rating
  • user_Name
    • Aug 2011
    i came across a motherboard with eight bad capacitors. They are located near the cpu. The original capacitors are rated at 4 volts 820 uF. Can I replace them with 6.3volt 820uF capacitors? I willing to read any other suggestions.
    Thanks for your time.
  • Rob Northen
    • Jan 2010
    • 137
    • Denmark
    Re: Replacing capacitors with higher voltage rating
    Yes, you can safely do that. Just ensure ESR and ripple (ripple of new ones can be higher) of the new caps match the old ones.
    • user_Name
      • Aug 2011
      ESR and ripple?
      It seems that I have two options.
      1. research ESR and ripple pertaining to capacitors. Determine the ESR and ripple of original capacitors. Then find new capacitors that have similar characteristics of original capacitors.
      OR
      2. just buy some Rubycon 6.3volt 820uF capacitors and hope for the best.
      The motherboard is from a Dell 8400 series.
      Must say that this website has provided me with some insights.
      • Rob Northen
        • Jan 2010
        • 137
        • Denmark
        Stick with #1
        On side of the caps, there are some letters, which indicates the series. Ie. MBZ.
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Stick with #1
          Ripple and ESR matter.
          Pay attention to how high [tall] they are because it might matter for heat-sink clearance.
          Normally 4v lytics are a bastard size and often they don't show up in data sheets.
          Often the are very short for their uF and the when clearance is an issue polymers are about all you will find to fit.
          As I recall we helped someone through recapping a Dell 8400 within the last month.
          Try the forum search.
          Mann-Made Global Warming.
          - Dr Seuss
          • Acerman123
            MSI K7T Pro2 Ver1 - capacitors have higher values?
            by Acerman123
            Trying to fix this board, MSI K7T Pro2.
            All Tayeh capacitors showed either as damaged or with uf values which were faf from what they should be so I have replaced them and all other capacitors except those big ones near CPU.
            The motherboard powers on but doesn't post. My PCI bios code reader will most of the time dsplay some some kind of code if there has been no power to board for a while but I don't think those codes mean anything in this situation. If I power off the board and try powering it on the second time the code reader usually doesn't show anythin. Unplug...
            08-12-2023, 10:00 AM
          • yuzupatogik
            Help with replacing Capacitors on Altec Lansing ATP 3
            by yuzupatogik
            I have this old (2004?) Altec Lansing ATP3 and i would like to replace the capacitors. I have identified 34 out of the 36 of them as Samxon GR of various capacities and voltages.
            I can't find datasheets for the Samxon in any of the following variants:
            10000uF 25 v - this one i really want to replace because i suspect it is what causes a dull hum regardless of the volume knob position or if the source is plugged in. I am eyeballing the Rubycon 25PK10000MEFCGC18X35.5 for this purpose. So if i pay a 10x the price part for shipping i might as well go ahead and...
            02-14-2025, 04:11 PM
          • Baste
            Replacing a bad Cap with higher value.
            by Baste
            Hello experts people,
            First time poster but lurking the Forums for few days now. I'm a beginner hobbyist who's trying to fix what ever I can and learned along the way. Right now what I have is a busted 58inch LCD TV with backlight issue. Long story short, I kinda found the issue (or atleast on the right track) it's on the power board with bad caps (broken pin). It seems an easy fix, just replace it with the same one and away it goes, but for whatever reason I cannot find the exact value in my place or online store in my country. The bad Cap is 39uf 450volts in parallel. The...
            09-22-2025, 01:56 AM
          • Tyran
            Replacing capacitors on a 12v 5000w Pure Sine Inverter .
            by Tyran
            Greetings folks. I darn near blew the heck out of my 12V inverter the other day by connecting it to a 24V battery source. :poof . Well lesson learned...... or maybe not . But in the meantime I have 4 Capacitors that need immediate replacing each rated at 16V 3300uf and 105deg. I saw a break down review You Tube video where the host suggested that the 35V Capacitors were a better choice for manufacturers to use. Another video suggested that replacing capacitors of higher Voltage is fine but that the 3300uf rating should be kept the same. Can someone please clarify what the functional benefits...
            04-22-2022, 08:26 AM
          • frannyjunk
            Vizio M60-C3 Replacing 1000uF 16V with 1000uF 35V capacitors?
            by frannyjunk
            Hi, my Vizio M60-C3 does not power on. No lights whatsoever. Upon opening up the TV, the power supply board has 4 bulging capacitors. Each is 1000uF 16V. I have read that one can use capacitors of the same uF and higher voltage rating, but is 1000uF 35V capacitor too high of a voltage rating? My local shop only has these higher voltage capacitors so would rather just buy the 35V variety if it is OK to use them.
            Any thoughts if OK to use these higher voltage capacitors?
            11-04-2021, 05:59 PM
