Sanyo WF datasheet
  • yyonline
    • Jul 2009
    • 692
    Sanyo WF datasheet
    I am looking for a datasheet for Sanyo WF capacitors. I can't seem to find one on Suncon's site. If anybody has a copy, let me know.
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Sanyo WF datasheet
    Like this one?
    Mann-Made Global Warming.
    - Dr Seuss
    • yyonline
      • Jul 2009
      • 692
      Exactly like that one. Thanks. Looks like it's between MBZ/HM and MCZ/HN spec-wise. I've been informed by a client that they have a server full of blown Sanyo WF capacitors. I haven't seen it yet. I know Sanyo is typically reliable, but are there any WF-specific concerns, or should I suspect overheating/PSU issues?
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        I've never heard of problems with them.
        OTOH: It's pretty rare to see them [WF] at all.
        I would suspect heat issues or a PSU problem.
        Would also consider poly as replacements.
        - Dr Seuss
        • Toasty
          • Jul 2007
          • 4171
          Originally posted by PCBONEZ
          <snip>I would suspect heat issues or a PSU problem.<snip>
          Or fakes...
          veritas odium parit
            Copy DMI info easily with Hex editing software and Macro script
            by SMDFlea
            Copying DMI information from an old bios to a new one is difficult for some members, often they have no experience with a hex editor,or some that have tried find it too hard.There is an option to make things easier for those members so that they don`t need to post their own bios backup for the DMI copying.
            Experienced bios modding members can help by posting in other threads the DMI offsets,macro script generated by the software and a download link to the software at softpedia mentioned in this guide,or post your macros in the comments here with a link to the bios request thread ....
            02-28-2023, 02:14 PM
          • Caimano
            Need to copy DMI info for HP ProBook 650 G2 Bios
            by Caimano
            UPDATE of JANUARY 5th : I am cancelling this post because problem has been solved by creating a new bios starting from the old one with correct dmi and cleaning ME. everything works fine . thanks anyway
            Hi, I am replacing a motherboard circus-6050A2723701-MB-A02 to an HP 650 G2 laptop because the original one was faulty. I bought and repaired a used MB which works fine now with its BIOS, but I wanted to copy the DMI data from the old to the new MB. I created with Flash Image Tool a new bios starting from the old original chip , cleaned ME region and new updated dump region extracted...
            01-03-2024, 05:19 AM
          • electomech-fixer
            First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheet
            by electomech-fixer
            I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
            I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if...
            09-15-2025, 01:42 AM
          • SoulFreeze
            Help finding datasheet for component marked G34662
            by SoulFreeze
            Hi, pulled this component, (I'm assuming it's a MosFET) from an LED COB video light. Im trying to find the datasheet so I can find an equivalent replacement but no luck. Any assistance with the datasheet would be appreciated.
            Failing that, a way to pick a suitable replacement component? If it's indeed a switching fet, I'm assuming I might need to measure the switching clock frequency and find a component that meets the power capacity?
            Its a pair of them driving a 130w Light. Takes in 19volts. I can borrow a scope to measure the switching freq....
            05-01-2025, 03:56 AM
          • Rainbow_Chameleon
            Searching Datasheet for AM113 IC by O2MICRO
            by Rainbow_Chameleon
            I got a dead HD6950 on Ebay to try my luck and repair it. There were a few broken off capacitors that I already replaced.
            Measuring the PCI-E lanes I got somewhat weird measurements, the gpu might or might not be dead.
            If I plug the GPU in, the core heats up and I also get VCore but on two inductors that measure 16 and 60 Ohms respectively (Memory and PEX I guess) there is no voltage.
            On one of the two buck-controllers (APW7165) the enable pin is pulled to GND and the other controller I just cannot find a datasheet for.
            So if anyone has a datasheet or at least...
            01-23-2025, 12:03 PM
