mainboard worth being recapped?
  • kai
    • Aug 2011
    • 8
    I am using a mainboard (MSI 7411-001 'Media Live Diva') which has a history of sudden failures but also has some unique features. The caps seem to be of lower quality but there are also reports of failures related to diodes. Regarding the overall qualitiy of the components - is it possible to evaluate by the attached pictures if it is worth trying to have the caps replaced by better ones?
  • severach
    • Aug 2007
    • 1055
    Re: mainboard worth being recapped?
    The brown X vent caps look like TK ATWY 1000uf 6.3v. Caps C781, EC79, and the one below EC74 look bulged. EC64 may be bulged too and there could be others outside the pictures. EC79 is not in a high heat position so the entire batch must be defective. Boards with bad caps have a high success rate. Keep an eye on those UCC KZG 470uf 16v too. They aren't in high heat posititions but KZG doesn't need much to go bad.
    The next problem is finding replacement heat sinks.
    sig files are for morons
    • Evil Lurker
      Warranty Voider
      • Feb 2011
      • 454
      Pretty much what he said, but I'd like to add be VERY careful not to chip the edges of the dies on the north/south bridge. It don't take much at all to fubar those.
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        If it at least runs and you don't have any cracked silicon [IC's, MOSFETs, etc.] then a recap should fix it right up.
        Worth it or not is up to you to decide.
        Mann-Made Global Warming.
        - Dr Seuss
        • kai
          • Aug 2011
          • 8
          Thank you all for your answers. However I would also like to know if other components of this mainboard (like diodes, transistors etc.) might be the root cause of this issue. Could you have another look into this, please. It would help a lot in the decision making whether to replace the caps or not.
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Can be, but usually not. - That's not something that can guessed.
            Visually Inspect them.
            Look for cracks, pits, shinny spots. - Anything that indicates melting or arcing inside.
            That can't tell you 100% they are okay but it can tell you 100% they are bad.
            Short of that you need to actually test each of them which [since some need removed to test] can eat up FAR FAR more time [whole days] than just replacing the caps to see if it works.
            I haven't seen a motherboard yet were a set of caps was worth a whole day of my time.
            Also there is no practical way to test some IC chips [like the chipset] without the board running so actually testing all the other ICs STILL won't -guarantee- a working board after the recap.
            Do the visual inspection.
            If you don't see any that are obviously blown then try the recap.
            For me the only exception to that is boards with the known defective nVidia chips.
            If those don't actually run before a recap I won't even bother with them. - Trash bin.
            I don't see those often enough to know which is which.
            Have to ask someone else for that.
            - Dr Seuss
            • kai
              • Aug 2011
              • 8
              Ok, thank you once again. So I guess I'll give it a shot.
              • Mirenia
                Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
                by Mirenia
                I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
                I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
                In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
                The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
                03-30-2025, 06:47 AM
              • orcic
                MASTER TL240 and new mainboard LW36BKC01
                by orcic
                I have an old MASTER TL-240 LED TV. Since it stopped working and it had a DVB-T receiver that is being dismissed in Italy, I've decided to replace the mainboard with a DVB-T2 one.
                The original problem was that when switching on the TV, the power LED was transitioning from red to steady blue, without showing video or audio.
                After checking some voltages on the power supply board (HKL-240101-B Rev. 1.4, HKL from now on) someone suggested me to replace the mainboard.
                Now I have some doubts about how to connect the new mainboard to the old power supply.
                First of...
                05-12-2023, 08:10 AM
              • Malva
                Problem LG 49UB850V (Mainboard: EAX65684604 / EBT62954607)
                by Malva
                I'm trying to repair my LG 49UB850V TV (WebOS 1.0, UHD model from 2014).
                Mainboard model: EAX65684604
                PCB marking: EBT62954607
                SPI chip: Winbond W25X20CLNIG Problem description:
                Originally, the TV would turn on (backlight and LED OK if I force them on), but it shut down as soon as any input was received from the IR sensor or remote. The backlight and power board were working fine.
                After testing and verifying the voltages (DRY ON, PWR ON, 12V/24V rails), I suspected a corrupted SPI firmware. What I tried so far:
                • I bought another
                06-25-2025, 02:07 PM
              • Devonavar
                Vizio M43-C1 - How closely do I need to match the mainboard number?
                by Devonavar
                I have a Vizio M43-C1 stuck in a reboot loop with no backlight.
                I've tested all the voltage rails coming out of the power supply and they are "normal" for this model (PS_ON & DIM go high when turned on, BL_ON & 3D_ON are close to zero due to backlight power flowing through the mainboard, 5VSB is 5V, and 12V is 19V, which is apparently normal for this board).
                Basically, I get similar results to Garry in this post: https://www.badcaps.net/forum/showthread.php?t=80346
                So, I've ruled out the PSU for now.
                The reboot loop...
                08-14-2022, 08:46 PM
              • l0lhaxz1
                QN65QN90A - Mainboard MLCC failed - now bootloop
                by l0lhaxz1
                Hi
                I have a QN65QN90A which was purchased around launch I guess making it about 1.5-2 years old... had been working fine until a few days ago, simply went black and would no longer turn on (at all). No standby light and no typical PSU relay click etc. Absolutely dead.
                Pulled it apart without doing much research first, suspecting the power supply as it had a faint buzz (I guess due to the forthcoming found short), investigated PSU for some time and concluded there was no fault that I could spot with the board removed.
                Came to learn after a bit more research...
                02-06-2023, 08:59 AM
