i7 920 SMD capacitors/resistors
    Re: i7 920 SMD capacitors/resistors
    nope tried again, still no dice.
    Its a bad idea to put in a smaller cap right?
    could someone else with a i7 920 please try testing their caps for me?
      I'm not sure what that means.
      That's hard to say without knowing what it's connected to.
      If it's in a bank of parallel caps you might not need it at all.
      I don't have one myself or I would.
      I use skt 771 Xeons or C2D and that's actually more than I need for anything.
      Were I you I'd look for one advertised as bad on ebay and see if you can get it cheap to cannibalize for the SMD parts.
      Mann-Made Global Warming.
      - Dr Seuss
        maybe I measured it wrongly and its 1.4 uf?
        Or maybe you measured the total capacitance of a bunch of them in parallel.
          Good Point.
          - Dr Seuss
            bingo!most of these caps are on vcore.
            some may be pullup/pulldown resistors.
            if damaged this may cause misreporting of type mentioned earlier.
              good point, but I was using the electrodes from point to point of the cap, would like to avoid de soldering good ones but any way of telling if I am?
                you are.
                remove any that are chipped/cracked too.
                  14uF is possible in smaller SMD ceramic, but I kind of doubt it.
                    The closest I found was too big and about $14 each.
                    At that price by the time you bought enough to fix that thing might as well have bought a new CPU.
                    - Dr Seuss
                      well if I have to remove them I will I guess
