Now THIS is a bad cap!
  • Hemingray
    KABOOM!
    • Jul 2010
    • 143
    Pulled from a Holmes "Blizzard" fan (Model HAPF622R). Fan would not power on whatsoever. Replaced this one cap and it's runnin nicely now.
    Never seen a cap of this type fail in THIS way before
  • Toasty
    • Jul 2007
    • 4171
    Re: Now THIS is a bad cap!
    See those type of failures in wall light dimmers when "standard" CFL's are used instead of incandescent. Or when used for any inductive load such as a fan. Probably caused by poor circuit design with that models "Breeze Modes". Install a 600 volt cap if you can.
    veritas odium parit
    • Hemingray
      KABOOM!
      • Jul 2010
      • 143
      Will do, have a similar cap in there for now, ordered some 630V caps though.
      • Toasty
        • Jul 2007
        • 4171
        veritas odium parit
        • b700029
          Banned
          • Sep 2010
          • 640
          What's the glob of stuff coming out? Melted aluminium?
          • Toasty
            • Jul 2007
            • 4171
            Yes. Metallized polyester/polypropylene film capacitor. Difficult to tell but polypropylene is generally suggested for high current AC work.
            Metallized polystyrene is not seen too much anymore and was usually a high-stability capacitor. Used a lot in instrumentation and radio where drift needed to be minimized. Could be had down to 1% tolerance. Recognizable (usually) as a clear axial or radial plastic cap that you can see the foil through.
            "Plastic film capacitors are insulated with polyester, polypropylene, polystyrene or other dielectric materials.
            Polyester film capacitors offer a high dielectric constant and high dielectric strength.
            Metallized polyester film capacitors provide excellent self-healing properties, allowing capacitors to withstand high-pulsed voltages without breaking the dielectric.
            Polypropylene film capacitors provide very low loss, low dielectric absorption, and high dielectric strength. They also offer very high insulation resistance and negative temperature coefficient.
            Polystyrene film capacitors provide extremely low losses, low dielectric absorption, good long-term stability, very high insulation resistance and a small negative temperature coefficient."
            Source: http://www.jbcapacitors.com/
            That's as good an explanation as I've ever heard.
            Last edited by Toasty; 07-28-2011, 12:55 AM. Reason: Correction - *not* polystyrene
            veritas odium parit
            • TheLaw
              • Jan 2011
              • 477
              Polyester seems to be good for lower voltages. Polyproplene is usually regarded as better "quality" and is more stable and can withstand more abuse.
              • watchmaker
                • Aug 2011
                • 6
                • Ukraine
                I've replaced three such caps in Maxus lamps...
                • Hemingray
                  KABOOM!
                  • Jul 2010
                  • 143
                  new 630V caps arrived today (5 of them), one installed into the fan, all's well now, even runs off my inverters nicely, so I can use this little fella in my van when needed
                  • Toasty
                    • Jul 2007
                    • 4171
                    Excellent!
                    In your van?? Is this running off an inverter?
                    veritas odium parit
                    • Hemingray
                      KABOOM!
                      • Jul 2010
                      • 143
                      Yeah. Does well from it too.
                      • Toasty
                        • Jul 2007
                        • 4171
                        Ahhh! Probably what blew the first one. Inverters are notorious for "dirty" power.
                        veritas odium parit
                        • Hemingray
                          KABOOM!
                          • Jul 2010
                          • 143
                          Not all too sure, it was given to me for free, bad cap and all.
                          • Toasty
                            • Jul 2007
                            • 4171
                            Ok. Thought it blew out on you. Mind the spikes from inverters. Does the same damage as I spoke of re: CFL on standard dimmer.
                            veritas odium parit
                            • Hemingray
                              KABOOM!
                              • Jul 2010
                              • 143
                              Ran it for an hour or so off of a Harbor Freight 750W inverter today at a parade, no ill effects. Kept me cool on a warm day while watchin.
                              • Toasty
                                • Jul 2007
                                • 4171
                                That's good to hear. Best of luck with it!
                                veritas odium parit
                                • AllElectronicsRepairs
                                  What is this component? No markings whatsoever.
                                  by AllElectronicsRepairs
                                  Hi All,
                                  Could anybody please recognize this component? It has no markings and there is no designator on the board. It has no continuity, diode test shows also OL both ways....
                                  05-24-2022, 10:25 PM
                                • Dusko75
                                  Need Help with Roland SC-88 Pro distorted sound!
                                  by Dusko75
                                  Hello All,
                                  I know what I'm asking here is not easy to answer but, here I go anyway. A couple of years ago I got a Roland (Sound Canvas) SC-88 Pro, 120v version, it was like new, manual, original box, everything was great, not a scratch. Played with it for a couple of months and it worked as expected. A few days ago I wanted to use it again and now the sound it's completely distorted, it's like a big crackly sound (I'm attaching a sample using the sound preview button: one short press, one long and another short at the end) .
                                  So, I opened it up and noticed that in...
                                  09-15-2020, 02:04 PM
                                • Luke Anders
                                  Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
                                  by Luke Anders
                                  A few details about the laptop itself:
                                  Name: Lenovo Legion 5
                                  Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
                                  BIOS Version: GKCN60WW
                                  EC Version: GKEC65WW
                                  Serial Number: PF39AQ7Z
                                  Board Model: NM-D562 Rev 3.0
                                  RAM: 16GB Installed, DDR4 (brand new)
                                  NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
                                  I bought this laptop recently from eBay as a faulty device....
                                  10-12-2024, 05:13 AM
                                • E--Man
                                  Samsung LED UHD TV - Bad Main Board or Bad T-Con Board? Pictures inside
                                  by E--Man
                                  Hi All,
                                  Thanks for reading. Based on the interesting fact that the vertical lines issue don't seem to effect the menus whatsoever but rather everything around the menu regardless of video is shown, I'm trying to set mine whether the issue is the main board or the t-con board.
                                  Again what's baffling is that the menu is not effected whatsoever. However, any other video displayed regardless of inputs or when no inputs exist exhibits the vertical lines and seem to effect black areas only.
                                  The lines are green in color when the tv is in "Game Mode" and...
                                  05-12-2024, 10:52 AM
                                • Twiesel
                                  MSI X470 GAMING PRO CARBON (7B78) USB Overcurrent
                                  by Twiesel
                                  I am currently working on a MSI X470 Gaming Pro Carbon that has a weird issue: The board is working fine on startup, but after the BIOS initializes, the board shows "USB overcurrent detected" on the screen and shuts down after 15 seconds. The issue is only happening when the system is ready to boot.
                                  What I have tried so far:
                                  -optical inspection: no damages whatsoever
                                  -BIOS update: The BIOS was updated to the latest stable version (I) using the CH341 1V8
                                  -PM_OC: I checked every double mosfet (7002N) that is connected to that line. All the PM_OC-signals are...
                                  09-02-2025, 10:40 AM
