Monitor caps
  • codyh
    • Jul 2011
    Monitor caps
    New guy here. My monitor went out so now I am doing all of my home computer stuff from my cell phone. Not fun, trust me.
    My monitor one day just went to a straight black screen. Thinking it was a part in my tower I switched everything over to some old parts I had laying around. Didn't fix it. When I went to turn my monitor off and then on again I noticed a squealing sound coming from the monitor.
    I then broke my monitor down to get to the main board. I don't know if the caps are blown but 2 of them appear to be.
    Can I get replacements at radio shack or another local store? Tallahassee, Fl
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: Monitor caps
    Try Digikey or Mouser. Radio Shack does not carry the appropriate caps. Unsolder those caps out of the board and tell us what it says on them.
    A working TV? How boring!
    • codyh
      • Jul 2011
      Re: Monitor caps
      Unsolder all of them or just what I think might be blown? About how much should it cost me to do them all?
      • ipman
        • Jul 2011
        • 159
        Re: Monitor caps
        It's quite hard to tell you the prices "across the pond"
        A few dollars anyway, not much. An ESR meter will tell you which ones to replace if you don't want to replace all of them, but will cost you several times more than all caps.
        • black6host
          Replacement caps for Samson Resolv studio monitor 65A Amp board.
          by black6host
          Good day!
          I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
          I'm going to replace the caps and I'll be the first...
          02-06-2024, 08:22 PM
          by momaka
          03-15-2023, 10:17 PM
          by momaka
          03-12-2025, 03:42 PM
          Westinghouse L2210NW LCD monitor - bad caps repair
          by momaka
          Here's another LCD monitor repair: Westinghouse L2210NW.
          Quick specs: 22” CCFL backlit LCD, 1680x1050 max resolution (16:10 aspect ratio)
          I got it with a bunch of desktops PCs from a repair shop that was trying to free up space a few years ago. It seemed like a cheap monitor, so I didn't really care that much at first when I picked it up (and indeed it is, picture-wise.) But hey, free is free, so I can't complain. Moreover, it looked clean and the screen didn't have any significant scratches or blemishes.
          Pictures of the monitor outside/case after a brief...
          01-11-2021, 01:14 AM
        • shelby5041
          clock radio / radio lifespan?
          by shelby5041
          hi
          ive got a modern digital clock radio approx 15yrs old
          my question is how long can a clock radio or a simple radio last ss farcas operating hours?
          since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
          the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
          it uses very little power just a few watts i would imagine that may have something...
          09-14-2024, 03:30 AM
