Reason the small caps don't need to be replaced?
  • incapacitance
    • Jan 2006
    • 29
    What was the reasoning for why the small caps don't need to be replaced? Will even the 100uf "Junkcon" caps stay good for a long time?
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Re: Reason the small caps don't need to be replaced?
    I've read they use a different electrolyte forumla. I don't know how true that really is, but in all my years, I've never seen the smaller ones fail. Rarely, I've seen 470uF caps fail, usually CHHSI's on MSI boards. On gigabyte boards, I've seen those 330uF 25v choyo's fail, which I always replace with 1000uF caps. If anyone else has some more insight on those little ones, I'd be all ears.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • Rainbow
      • Aug 2005
      • 1375
      The thing that I saw on various boards: low ESR caps are often all bad but general purpose ones are all OK. The small caps are almost always general purpose.
      • PeteS in CA
        • Aug 2005
        • 3581
        • USA, Unsure of Planet
        Smaller caps are usually for local decoupling or timing circuits. They aren't subjected to the kind of ripple current stress the low Z types used in VRMs are.
        PeteS in CA
        • cods69
          • Oct 2005
          • 92
          I've been wanting to post this picture for a while....this thread seemed a good enough reason.
          I damaged the cap when assembling this 'Solar Cybug' kit with the iron, but it worked fine for years.
          A few months ago (when discovering capacitor problems in my mobo) I noticed the bug had a leaky 1uF cap and it no longer behaved (steering circuit).
          Even though the leak was obviouly initially caused by my mistake, the hole in the side of the cap where touched with the iron is far worse now than when it happened. There has been much deterioration over about 5 years and that is quite a leak of white stuff from the bung!
          • dood
            Deputy dood
            • Mar 2004
            • 2462
            Can't really blame that on the cap, though
            Ludicrous gibs!
            • cods69
              • Oct 2005
              • 92
              Originally posted by cods69
              I damaged the cap
              I think I covered that.
              In answer to the OP's question, this small cap requires replacing.
              • gonzo0815
                • Feb 2006
                • 1600
                I agree to that, but you can`t go realy for the uf rating. It is only a rule of thumb. On grafikboards there are usually many 330v caps which are indeed low esr ones, but not that often on motherboards. So in generell lock on the capazitor, if it is an low esr ones it is prone to fail, if not you can assume there are no need for that. In doubt you have to look in to the part of the cirquit. If it is not an power supply nor an switching power suply or so ones, generally esr is`t that important.
                The main reason, that low esr caps are prone to fail is the fact, that the elektrolyt have to contain water to archive the low resistance. On the other hand, water and Aluminia are prone to corode and develop some H2 gas. To avoid that the manufacturer hase to add some additives to prevent that. This is pure science. But in order to make an low esr capazitor, you don`t need mutch R&D, you can bay all what is needed an fill it in a fancy capazitor wraping machine. The bad caps manufactuere do so. They know little to nothing about how to ensure quality of the raw material or how to messure that. But they can do it cheap.
                No longtime tests are don etc.
                  by momaka
                  03-15-2023, 10:17 PM
                • zlr8r
                  HP Probook 640 G5 - replaced blown components, getting power led, fan full, 5-flashes on CAPS Lock and NUM lock, black screen
                  by zlr8r
                  Hey guys, bit stumped with this laptop after replacing 2 blown components i.e., MP86493, MP2979A.
                  To begin with, this laptop was dead-dead.
                  Now with replaced (visibly) blown components, i do get some progress; after connecting battery or main cable;
                  • am getting white power led
                  • 5-long-flashes on CAPS Lock and NUM lock
                  • then, fan full speed
                  • CPU heats up some (smaller die PCH, does not)
                  • always constant black screen no matter what's tried
                  • no USB recognition
                  • no HDMI output
                  this is as far as I can get with it and not sure where to inspect next ?
                  I tried...
                  03-27-2024, 03:13 PM
                  HP 280 G2 Small Form Factor PC i3-6100 Specification for Upgrade or Repair
                  This specification for the HP 280 G2 Small Form Factor PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 280 G2 Small Form Factor PC boardview and 280 G2 Small Form Factor PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                  09-12-2024, 03:44 PM
                  HP ProDesk ProDesk 600 G2 Small Form Factor PC ProDesk 600 i5-6500 Specification for Upgrade or Repair
                  This specification for the HP ProDesk ProDesk 600 G2 Small Form Factor PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk ProDesk 600 G2 Small Form Factor PC boardview and ProDesk ProDesk 600 G2 Small Form Factor PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                  09-12-2024, 03:36 PM
