is this a bad recap?
  • eppidrummer
    • Jan 2011
    • 65
    I have recapped about 40 or more boards with 100% success until now.
    Recapped what I think is a gx270. I replaced every cap with rubycons of the same value but used poly caps along v-core (820 2.5). PC booted and ran 24hrs unattended with no issues, updated drivers and all was well. I bring the pc home to hook up and let run for a few days and now its doing weird stuff.
    Start with a beep everytime I moved the mouse. I then hooked up usb mouse and all was well but now no keyboard. I reboot and keyboard now works but is typing sometimes wrong characters or typing twice with one hit. Changed the ram and still same problems.
    Could this be the result of the poly v-core wrong(to many, not enough?) or a bad cap somewhere else? Not sure were to start?
    After I recap evry board I do go over all the traces with a magnify glass to check for solder splatter or loose joints so I dont think that is it. Should I just scrap the board?
    Thanks for any input.
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: is this a bad recap?
    No, Vcore caps shouldn't do that.
    Sounds like a problem with +5v or a ground.
    USB & PS2 both use +5v.
    First check mounting didn't sift somehow when you moved it.
    Mann-Made Global Warming.
    - Dr Seuss
    • eppidrummer
      • Jan 2011
      • 65
      Here is a pic(bad one) if it will help any?
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        I'm trying to say maybe board got grounded to tray or something similar when you moved it.
        No random screws rattling around under the board are there?
        - Dr Seuss
        • eppidrummer
          • Jan 2011
          • 65
          I will take the board out and check everything out. Thanks for the input!
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Also check that USB ports didn't get bent inside.
            I've seen bent ones ground the contacts to the sheet metal surrounding the port.
            - Dr Seuss
            • Francisco.s
              CPU vcore missing in HP workstation Z2 Mini 4G
              by Francisco.s
              Hi, have a HP workstation Z2 Mini 4G for repair with CPU vcore missing.
              The resistance at the output of CPU vcore coils, is less than one ohm so I think CPU could be damaged, but no mosfet are damaged.
              It mounts an i7 8th gen, and have only i5 7th gen for test, but I think it is not compatible.
              Without CPU in the socket there is no short, but there is no vcore voltag, and it emits a beep like no detecting ram.
              The controller chip for cpu vcore is a MP2949A, and has no enable voltage at pin 37.
              I wonder which circuit generates this enable...
              04-22-2024, 12:35 PM
            • CapLeaker
              Poly VVX-250 VOIP POE problem not booting fix
              by CapLeaker
              I've got a bunch of Poly VVX-250 VOIP phones that work fine as kind as long as they are plugged into the wall wart. Recently I got around to install a couple of TP-Link 5 port POE switches that are added to the existing plain Jane 24 port unmanaged switch. Great!!! Finally I am able to ditch the wall warts from these phones making more space on the desk, plus I am gaining some badly needed power outlets. So I thought.
              Plugged in the first VVX-250 into the POE switch, booted up no problem. Plugged in the other Poly phones and they start to boot anywhere from 5 to 15 seconds,...
              11-25-2023, 10:46 AM
            • mikzs
              Rx580 8gb sapphire nitro+ turn off vcore randomly
              by mikzs
              Hello, this is my first post, English is not my native language but I hope you understand me. I recently got a 580 that didn't turn on the typical short mosfet, as I didn't know exactly which one was short, I unsoldered them until I got the bad one out, I was able to remove the short and identify the bad mosfet, the gpu gives video again! but it has a problem that completely turns off vcore at random times or if I try to put a load on the gpu vcore drops to 0 I don't have much idea why because I don't know much about sapphire, any advice on where I could start looking or what problem it could...
              11-06-2023, 12:28 PM
            • jm942
              Hp Lh482p 5 short 3 long short after cpu vcore mosfet replacement
              by jm942
              My laptop went dead and after checking ,the main 19 volt power rail was shorted. After some checks i could identify that a high side vcore mosfet was shorted.
              I replaced the mosfet and now the white powerled is present , fans start spinning but capslock shows the famous 5 long and 3 short code.
              I checked the vcore voltages after replacement and i get for all 1.01 V so means for me that the driver is still working of the replaced shorted mosfet. On the Nvidia i measure around 0.8 V after the mosfets.
              I did voltage injection on the cpu with 0.7V and i have a current...
              07-11-2024, 05:11 AM
              ASUS P5GC-MX motherboard recap
              by momaka
              Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
              This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
              So here is what the motherboard looked like with its original caps:
              CPU VRM area up close…...
              01-27-2021, 11:59 PM
