When did they first start producing "bad caps"?
  • incapacitance
    • Jan 2006
    • 29
    When did cap manufacturers first start using the electrolyte that has caused so many caps to fail prematurely?
    Seems like a lot of equipment from 2000 (and later) has suffered from bad caps, so were the first bad caps produced in 2000? Would it be safe to say that any component manufactured in 1999 or earlier will not have any of these bad caps?
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: When did they first start producing "bad caps"?
    i remember this issue showing up in socket 7 boards that used a switching vrm.
    iirc the first were around 97.
    • arneson
      • Sep 2005
      • 1267
      SMT caps in Sony Handycams are all leaking from about mid 90's vintage. I have 100s of handycams each with hundreds of badcaps.
      I know there are cap replacement kits available but I will not spend the time effort or money on them.
      Jim
        by momaka
        03-12-2025, 03:42 PM
      • eryjus
        by eryjus
        05-10-2023, 11:21 AM
      • Paxman_Swede
        by Paxman_Swede
        Hello!
        01-14-2025, 09:51 AM
      • captain150
        by captain150
        03-16-2025, 07:34 PM
      • Foetuss
        Gigabyte GA-6OXT :: caps question
        by Foetuss
        Good evening
        I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
        Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
        But I was also suprised about the bigger boys, which are 330µF 25V.
        Could it be they used 25V caps because they were cheaper / available at that time?...
        02-11-2025, 12:22 PM
