Replacing badcaps with new, higher capacitance
  • adict2jane
    First post!
    I am relatively new at modding electronic circuits in general. I have a quick question.
    I need to replace a bunch of blown 6.3V 2200uf and one 6.3V 1800uf caps on a Dell optiplex 745 mobo. I am going to get a bunch of 2200uf rated caps, can I just use a 2200uf cap to replace the 1800uf? I am pretty sure I can but just want to make sure.
    thanks!
  • rhan101277
    • 10
    Re: Replacing badcaps with new, higher capacitance
    I don't see why not, just don't reduce the voltage.
    • delaware74b
      • Apr 2009
      • 628
      If you're in US or Canada, I'd recommend getting caps from the following suppliers: Badcaps.net, Digikey.com, Mouser.com.
      Do NOT purchase caps from retailers such as RadioShack, etc. They sell general purpose caps and will not perform correctly in any computer, especially the Dell and HP ovens.
      Please follow the site's recommendations of attaching photos. I recommend you attach clear-focused pictures no larger than 2000x2000 pixels. In order for us to help, good photos of caps in question, along with brand, series, capacitance, voltage, date code, dimensions, board model and revision are a must. For example: Rubycon MBZ, 1800 uF, 6.3 volts, 10 x 16mm, etc on a Dell Optiplex 745 board (form factor here), v 1.1
      Stupidity should be a crime, especially for drivers. I have NO patience for them.
      • Agent24
        I see dead caps
        • Oct 2007
        • 5038
        • New Zealand
        The value is so close I guess it wouldn't matter, personally I would replace with exactly the same capacity - unless I knew for certain it didn't matter or it was advised to increase capacity for stability\reliability or something.
        -David VanHorn
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          [Repeat] Personally I like to replace with exactly the same capacity.
          That said..
          The uF on caps is +/-20% and 120% of 1800uF is 2160uF.
          - Plus uF tends to go down as caps age.
          Probably [and in theory] not a problem..
          .. But you have to ask yourself:
          "if they were ordering 2200uF in droves anyway why would they complicate the assembly line by use a single 1800uF there if the uF didn't matter?"
          Mann-Made Global Warming.
          - Dr Seuss
          • adict2jane
            Hmm...
            Ok, thanks for your reply everyone! Sorry its been a while, life is crazy...
            Maybe I was thinking about capacitors in the wrong way, it's been a while, haha.
            I was viewing a capacitor like a battery and the Farad rating as a measure of capacity. A 2200uf cap has the same exact properties as a 1800uf cap at the same voltage except it can store more energy (which would simply be an excess and never used in this case). Is this wrong?
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              No it's not wrong but that's far from the only thing that caps do.
              uF affects how long it takes to charge the cap and that is sometimes used to control how long it takes a voltage to get to some point where it 'trips' another circuit on or off.
              [For instance when starting a PC if voltage is not to 80% of the nominal value within about 50 milliseconds a safety feature cuts-in that turns the power supply back off.]
              Huge uF caps could keep the system from coming on because they take so long to charge that the safety clock times out and trips the PSU off every time.
              In that case to uF would probably have to be really huge but there are all kinds of smaller control circuits that do similar things.
              uF can also affect frequencies and there are several timing circuits on a motherboard.
              Look closely at a mobo.
              You'll at least one [and probably several] quartz crystals [usually in ob-long metal cans] that help set the frequency for timers [oscillators, clocks].
              Frequency also comes into play when filters use an inductor in combination with a cap. The values [uF and uH] are chosen to optimize filtering at some frequency.
              If you change one value without changing the other then the filter will be less efficient at removing the expected noise [ripple] frequency.
              If you don't want to trace out a circuit and do the math to find out what the cap does it's best to stick to the original uF value.
              And that's just the concerns about uF.
              ESR and Ripple are important too and that's a whole 'nuther discussion.
              Motherboard caps are low ESR [and high Ripple] caps - and GP electronics places like Radio Shack & Fry's Electronics don't have them.
              - Dr Seuss
              • SwedishDiesel
                Dell Optiplex GX260 - Advice Needed for Polymodding Motherboard
                by SwedishDiesel
                Howdy folks,
                I have an Optiplex GX260 that blew a couple of those troublesome Nichicon HM series (ultra low ESR) electrolytic capacitors. Because said caps are obsolete, they are pretty much impossible to find on the market; I did find a listing for some but I believe they are counterfeit. I feel the easiest thing to do would be to replace all the blown caps with polymer ones. I am by no means an expert in electronics, and I've found a fair bit of conflicting information, so any guidance or confirmation would be greatly appreciated. While from a practical standpoint it's not worth...
                10-30-2021, 12:47 AM
              • Baste
                Replacing a bad Cap with higher value.
                by Baste
                Hello experts people,
                First time poster but lurking the Forums for few days now. I'm a beginner hobbyist who's trying to fix what ever I can and learned along the way. Right now what I have is a busted 58inch LCD TV with backlight issue. Long story short, I kinda found the issue (or atleast on the right track) it's on the power board with bad caps (broken pin). It seems an easy fix, just replace it with the same one and away it goes, but for whatever reason I cannot find the exact value in my place or online store in my country. The bad Cap is 39uf 450volts in parallel. The...
                09-22-2025, 01:56 AM
              • mikkele86
                Luxman R-5045 - Capacitor at amplifier output broke, can i replace with higher capacitance ?
                by mikkele86
                Hello Im renovation a Luxman R-5045
                On the attached picture there is a cap 0.047uF (47nF) and a resistor, 10ohm. What is their purpose ? and what would happend if I were to replace the caps with lets say, 10nF or 100nF ?
                because thats what i got in stock :/
                04-16-2024, 12:37 PM
              • Delicieuxz
                Replacing caps in an old speaker system. Should I use a higher value here?
                by Delicieuxz
                I'm recapping an old Creative Labs / Cambridge speaker system / subwoofer. At 4:33 in this video, the person looking at what he says are the speaker caps in the system says they are 470 uF, and that he'd use much larger caps if he was building it.
                https://youtu.be/1LRIzePlma0?t=273
                I'm wondering if I should use something larger for the recap job, and what using larger caps will do for it.
                Would 680uF be good value to try in place of the 470uF originals?
                06-25-2023, 08:27 PM
              • cloppy007
                [MSI KT3 Ultra ARU] Advice on capacitor choice
                by cloppy007
                I've found out that the all the Nichicon HM(M) caps on this board are faulty and need replacement. However, I didn't plan in advance and I don't have good replacement caps.
                The original values are 2200uF, 6.3V, 5mm pitch. According to the datasheet, the rated impedance should be around 13-18 uOhms.
                There are 8 of them, 3 to the left of the CPU socket and 5 on the bottom, very close to the northbridge. They are all connected, according to my multimeter.
                I think I recall hearing that I don't have to use the same capacitance for in series...
                08-21-2023, 03:18 PM
