Bad caps on Inverter Board?
  • Remeniz
    Thats me!
    • Jan 2011
    • 19
    Hi peeps.
    I've got a LCD screen with a faulty backlight inverter board; everytime I try and power up the monitor the backlight comes on briefly, the PSU short-circuit protection kicks in and the whole lot turns off. This on/off cycle will carry on until you disconnect the power.
    So I un-plugged the inverter board and the TV powered up fine. Plug the inverter back in and it shorts again. Now if I keep the inverter board plugged in and remove all 6 cathode connections the TV powers up fine.... then if I plug back in the tubes the TV stays on, but without the backlight.
    Anyway I removed the power, plugged in 1 out of 6 of the cathode tube connections and turned it back on and the PSU, as above, cycles on/off protecting itself from a short. But when I put my digital multi-meter, on a volt range, across the small blue 18pF caps near the transformers the output from that tranny comes on and the shorting stops, TV on! I know this cause my digital meter goes crazy with high frequency AC readings. No back light though cause only one side of one tube is connected to the inverter; three tubes, 6 connections, 6 transformers and 6 caps.
    So can this mean the 18pF caps are bad? I then tried this on all 6 outputs, and the same happens.
    Soundcraft CPS-450 and CPS-550 (Rebuilds - Completed!)
    Samsung PS42V6S - in repair (New Y-SUS Board Completed)
    Philips 32PFL7782D/05 - in repair (PSU or Main Board - Selling)
  • Remeniz
    Thats me!
    • Jan 2011
    • 19
    Re: Bad caps on Inverter Board?
    Here's the cathode inverter board...
    I did try to upload but it failed.
    • retiredcaps
      • Apr 2010
      • 9271
      The max resolution is 2000x2000 and the max size is around 2MB. If you exceed that, the upload will fail. There are a number of programs to resize or just take another picture with lower resolution settings on your camera.
      --- begin sig file ---
      --- end sig file ---
      • Remeniz
        Thats me!
        • Jan 2011
        • 19
        Thanks man.
        Here's the board....
        • retiredcaps
          • Apr 2010
          • 9271
          1) It would help if you list the model number of the TV.
          2) The AC voltage where you are measuring can easily get to 1500V AC. Enough to do serious damage to your multimeter and you.
          3) From what I know, those blue caps rarely fail and when they do you will know it.
          4) If you are getting a brief backlight flash, you have likely have 2 seconds to black.
          If you hookup a dvd player, do you see the movie playing on the screen if you shine a flashlight on it?
          5) If yes to #4, the purple electrolytic caps can cause 2 seconds to black.
          6) Another possibility is the inverter transformers. You can measure the resistance of secondary pins (with power off and lcd unplugged). The secondary pins are the ones "feeding into" the blue caps.
          7) Another possibility is that you have a bad ccfl tube.
          5,6,7 and are described for computer lcds at post #13 and #14 at
          https://www.badcaps.net/forum/showthread.php?t=10419
          • Remeniz
            Thats me!
            • Jan 2011
            • 19
            My bad.
            TV model is Toshiba NR 20VL44B. The backlight comes on very briefly, like it's trying to start up, but it's this initial start up process that is causing problems and is shorting the PSU. The PSU has a 5A limit after which it will shut down for 1 second and re-start. I just assumed that the multimeter's high internal resistance across the small cap's was fixing the problem so it needed new caps.
            Also the picture is visible on the screen without the backlight.
            I'll refer to the thread you linked...
            Thanks.
            • retiredcaps
              • Apr 2010
              • 9271
              I should mention that "2 seconds" guide is meant for lcd troubleshooting. The LCD TVs are an order of magnitude more difficult to troubleshoot and you very well could be right in looking at the PSU versus the inverter section.
              • Remeniz
                Thats me!
                • Jan 2011
                • 19
                The external PSU was cycling on/off without the inverter board.
                Also I hooked up the high current output from an ATX PSU to the monitor and guess what?... It powered up, albeit without the backlight; 11.6V isn't enough for the inverter to start up the cathodes, it needs 15V.
                So it seems the PSU is not liking the initial current demands; with the ATX PSU running the monitor it needed 2.5A, 4A max, to start the cathodes after which it drops to 860mA. But to have the PSU crap out with just less than an amp means it's had it.
                Do I go with another switching PSU, for efficiency, or a non-switching type? If switching then i'll go with a 6A instead of 5A.
                • Remeniz
                  Thats me!
                  • Jan 2011
                  • 19
                  Just a quick re-cap...
                  I opened up the external PSU and replaced the high voltage filter electrolytic on the primary side and it works fine now.
                  Thanks!
                  • m1ch43lzm
                    by m1ch43lzm
                    05-12-2025, 08:37 PM
                  • Dani_2024
                    by Dani_2024
                    10-28-2024, 05:06 PM
                    by momaka
                    03-15-2023, 10:17 PM
                  • lostone
                    Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                    by lostone
                    Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                    First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                    When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                    05-19-2024, 11:40 AM
                  • black6host
                    Replacement caps for Samson Resolv studio monitor 65A Amp board.
                    by black6host
                    Good day!
                    I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
                    I'm going to replace the caps and I'll be the first...
                    02-06-2024, 08:22 PM
