EMachine Recap Success
  • dobber
    • Jul 2008
    • 83
    Good day, I had to recap a EMachine ECS Board today, it had 5 blown 6.3v 1800uf caps. It was causing shut down on boot to windows, I put in new caps and all s good now.
  • yyonline
    • Jul 2009
    • 692
    Re: EMachine Recap Success
    Good job on getting the board working again. ECS often uses OST capacitors. I'd recommend replacing all the OST on the board, not just the ones that have obviously failed. See, OST sometimes fail without showing any external signs of leaking or bloating. Even a few off capacitors can cause a computer to run slowly or have stability issues, even if they're not bad enough to cause it to not boot up completely.
    • dobber
      • Jul 2008
      • 83
      I will take that to heart and change out the other few of them. I did not know they were cheap caps.
