Faulty formula theory must be wrong?
  • timjand
    • Mar 2005
    • 8
    I know the yarn about the faulty stolen formula. However I've just had an Epox EPEA+ fail with bad caps - it was purchased in March this year. The bad caps are GSC; they are not the largest on the board, but all seem to be 1000 uf and 6.3v. Surely if this problem is still occuring 3 years after the main problem in 2002, it must be more than one faulty formula.
    Disappointed with Epox because of this; won't buy again. It should know enough about this problem by now.
    Tim
  • cods69
    • Oct 2005
    • 92
    Re: Faulty formula theory must be wrong?
    At a guess, there would be huge inventories of these bad caps in various warehouses, which would appear for sale at a bargain price, from time to time.
    • Rainbow
      • Aug 2005
      • 1375
      GSC is crap company that was found when these crappy caps appeared. Motherboard manufacturers are stupid enough to buy the same crap again and again - e.g. Epox still uses GSC which fail on all boards.
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        Yes, cods69 is probably correct, check the date of the caps... They might very well be a couple years old even if the board is new... Btw, can you please recheck the model name? EPEA+ does not seem to exist?
        And can you also please post some pictures?
        Lastly, GSC is 100% crap, even if they have been created this year they will fail if run in harsh environments (like on a hot mainboard for example)
        • MD Willington
          • Sep 2004
          • 702
          More than a guess, they produce them by the millions... As an engineer said to me, "They are like Jelly beans"... ie billions produced to this date...
          Just because the year changes, doesn't mean they can't use product from last year..
          MD
          Ya'll think us folk from the country's real funny-like, dontcha?
          The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
          • AK0R
            • Mar 2005
            • 204
            In this post, he calls it a 4PEA (which gets several hits in search): https://www.badcaps.net/forum/showthread.php?t=1215
            • timjand
              • Mar 2005
              • 8
              Apologies, it is 4PEA+ (+ means onboard RAID).
              Done - see post in Epox secion.
              • timjand
                • Mar 2005
                • 8
                This still doesn't let Epox off the hook IMO. It must have known about the fault two years on; surely a company with any sort of quality control would ensure that the faulty components were no longer used.
                Tim
                • timjand
                  • Mar 2005
                  • 8
                  Not sure how to check the date. Aside from the ratings, they are marked T20K or T20F and have the letters RE in a small box. They are also marked with a temperature: 105 C.
                  Tim
                  • cods69
                    • Oct 2005
                    • 92
                    Agreed.
                    This is where the definition of "faulty" comes into play.
                    By definition of time (for arguments sake, say 1,000 years), all components will probably be faulty. Some will die within 6 months, some within 3 years, some around 5 years etc.
                    Within a specific manufacturers specs for the Warranty, they would measure component lifetime (relative to warranty) and reliability, versus costs of say large batches of easy to get components or perhaps small batches of rare expensive components.
                    Every manufacturer would have a cost/reliability/quality balance they would adhere to. I guess we now know where Epox sits on the scale.
                    • AK0R
                      • Mar 2005
                      • 204
                      Manufacturers of PC motherboards and component boards have the same trouble. Do you really expect them to dump several thousand dollars worth of inventory that *may* (or may not) be bad, and bring their production lines to a halt, until new product can be received? Lead times are often measured in weeks, and even a day's lost production means several thousand dollars of lost revenue.
                      And provided the parts that are in inventory last as long as the warranty after installation, the manufacturer has met his commitment to the customer. They don't care that failure means, at best, lost productivity and at worst, failed motherboard, CPU, memory, expansion cards, and/or power supply. We have two choices, and they both involve our pocketbooks. Pay higher prices for high-quality parts up-front, or pay for high-quality replacement parts and repairs when the original cheap crap fails (and hope that there is little or no collateral damage).
                      • hotcrossedbuns999
                        IdeaPad 1-14ADA05 Laptop - (Type 82GW) bios
                        by hotcrossedbuns999
                        First off, I saw the other thread, but that seems to be a different version (same model though), because I tried all of the linked bioses and none work. They actually cause the laptop to do nothing. At least when I use the bad bios, lights come on. (charging light, power button light, and caps lock light), but no screen.
                        Another thing is that the bios has a different name (Old thread has "e8cn36ww" and mine is "fqcn31ww") and the BIN in this thread (below) are 8mb, and the CAP file that I get is 16mb (after using innextract 1.9). I don't know how to get the BIN...
                        05-21-2025, 05:59 PM
                      • Soulzink
                        Samsug washing machine. Power supply DC41-00189a board issue
                        by Soulzink
                        I am trying to fix a samsung washinmachine power supply main board.
                        I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                        Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                        The power supply board reference is the following: DC41-00189a
                        I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                        04-19-2025, 06:26 AM
                      • JarzabekPZ
                        HUAWEI Matebook D15 Bom-WDQ9 - faulty onboard RAM
                        by JarzabekPZ
                        I have a Huawei Matebook D15, MB DAH98PMBAB0 REV. B with faulty onboard RAM. Laptop starts but when loading Windows instantly gets BSOD's. Passmark Memtest shows multpile faults on test 11. Memory is itentified as 2 modules Samsung M471A5244CB0-CWE, which are available as standard so-dimm. Is it possible to desolder memory from such module and solder it on the MB? How to identyfiy which one on the MB is faulty?
                        08-08-2025, 03:40 AM
                      • Spudgun
                        Why doesn't current just bypass faulty capacitors.
                        by Spudgun
                        Hello esteemed members. I appreciate that my question will strike some as being somewhat childishly simple, but it genuine perplexes me! I have repaired several laptops before by removing a faulty capacitor that was short-circuiting the motherboard, whereupon the laptop would then work. For me, it begs the question that, if the current can bypass where the capcitor was when it has been removed, why didn't it just bypass it when it was present and faulty,? I can't get my head round the premise that if the other side of the capacitor is connected to ground, then why doesn't the current simply bypass...
                        04-01-2025, 10:33 AM
                      • b-slayer
                        Acer A317-53 need help to disable faulty onboard ram
                        by b-slayer
                        Hello.
                        I have an Acer Aspire A317-53 laptop with faulty onboard ram modules, after online searches, I have only found two options to get it working :
                        - first one is to modify le bios to disable the onboard ram.
                        - second one is to disable the onboard ram by desoldering some components on the mainboard.
                        so after some hours google-ing, i have to give-up the modified bios option, main reason is I couldn't find anywhere a such modified Bios, alternate reason is that if windows update makes a bios update, the problem is always here...
                        so i found that my motherboard...
                        10-12-2024, 03:46 AM
