Identify this Ceramic Capacitor
  • skuppyJ
    • Jan 2011
    • 5
    So my monitor broke and I took it apart and found two burnt locations with possibly faulty components. I think these components are ceramic capacitors, but I am not certain. Can you please help my identify them?
    And they do not have any markings on them. I emailed Viewsonic for their schematic..but I doubt they'll give it to me.
    Thank you guys.
  • Trinite
    • 143
    Re: Identify this Ceramic Capacitor
    Those look like input power filter capacitors. It appears that they are connected in a Y configuration, which means that it and the adjacent capacitor should be identical. You can then reference the other one for a replacement.
    Note: This is only the case if both capacitors are attached in a series configuration between line and neutral (AC input). They will be attached like this:
    Line --- Cap 1 --- Ground --- Cap 2 --- Neutral
    If those ports are for CCFLs, then those are not input filters. If so, then you may not be able use the above method to identify the other cap (unless you can establish that both are identical).
    • Pyr0Beast
      • Feb 2009
      • 406
      Use 5kV caps of appropriate capacitance, 2.2nF or something.
      They limit current to the cfl. Replace all there are.
