68uf 400v Capacitor making a clicking sound....Advice please
  • katana
    • Aug 2010
    • 4
    my JVC home cinema DVD player, suddenly died . Suspected the power board and replaced a few 'suspect ' componants. Switched on, and was working fine......switched off (10 minutes later) and now its dead again (no standby light etc) After removing the top casing and plugging in ...I could hear a faint clicking sound....coming from the main, low profile 400V 68uf cap !!! I want to replace it.
    I assumed that being a power supply board all the caps would be low ESR ...but cannot find a replacement cap with the right dimensions/ rating that has a low ESR.
    My questions are, does the clicking sound mean the cap is bad (internal arcing ?) ? Does the replacement cap need to have a low ESR ?
    I'd appreciate any advice, thank you
    Regards David
  • retiredcaps
    • Apr 2010
    • 9271
    Re: 68uf 400v Capacitor making a clicking sound....Advice please
    Please post a clear focused picture of your board using the manage attachments button (do not post inline).
    On most computer LCD power boards, the clicking indicates that the SMPS controller is trying to start. Next to the SMPS controller is a small startup/run cap that is usually 22uF 50V or in that range. These little caps can go bad without showing signs of bloating.
    In the LCD world, that cap is responsible for the SMPS not being able to start in the majority of the cases. Additionally, it is rare for the big cap, but not never, to fail.
    If the big cap is the culprit in this case, it does not have to be a low ESR cap.
    Anyway, the picture will help a lot.
    --- begin sig file ---
    --- end sig file ---
    • katana
      • Aug 2010
      • 4
      Hi Retiredcaps,
      thank you for replying . Here are a few pictures of the board. The IC near to the large cap has been replaced (afterwards the player 'worked' for 10 minutes, but after turning the power off ....the player refused to work. The IC was tested afterwards and was found to be OK). All the resistors and diodes in and around the large cap seem to checkout OK.
      The top of the large cap looks to be very slightly distorted, photo's do not show this. The replaced IC is a str g6651 (flyback switching regulator)
      Kind Regards David.
      • Pyr0Beast
        • Feb 2009
        • 406
        I would replace that 400V cap.
        • retiredcaps
          • Apr 2010
          • 9271
          Might as well order a replacement for C914 as well. That is the little cap that I think is part of the startup.
          • Toasty
            • Jul 2007
            • 4171
            Replace C914. Panasonic FM or better. Mains cap is fine.
            veritas odium parit
            • Pyr0Beast
              • Feb 2009
              • 406
              Oh yeah. Failed to see that one but I was looking for it. Defenitely replace it is probably the cause of fault and 400V cap could be just fine.
              • katana
                • Aug 2010
                • 4
                Thank you all for taking the time to reply, greatly appreciated.
                Already ordered a new 68uf 400v cap but got a 105 degrees temp rating, instead of the standard 85. Will get a replacement for C914 and fit it first....to see if it cures the problem (before replacing main cap) Then if this fails to work I'll then replace the main cap. This way I'll know which caused the fault ....and, if the main cap, perhaps the clicking may help diagnose a faulty one (for others on the forum) ??
                Will let you know how I get on.....thanks again
                Kind Regards David
                • retiredcaps
                  • Apr 2010
                  • 9271
                  That would be great. Many of us want to know what is root cause.
                  • Pyr0Beast
                    • Feb 2009
                    • 406
                    Bootstrap caps often fail.
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 5095
                      • New Zealand
                      Tick-tick-tick - Too little or no load. In a TV or monitor using an SMPS, this is likely due to a lack of horizontal drive or a blown fuse or fusable resistor in the horizontal deflection system. The power supply is in a repeating cycle of starting up, being unable to limit the regulated voltage to a safe value, and shutting down. Attempting to power up an SMPS without an adequate dummy load may result in these symptoms.
                      From: http://www.repairfaq.org/sam/smpsfaq.htm#smpsstsm
                      I have also read about internally arcing diodes making funny noises. If the new capacitors don't solve your problem I'd look at the diodes in that area of board which has obviously had the most heat.
                      -David VanHorn
                      • Pyr0Beast
                        • Feb 2009
                        • 406
                        Had a lightning strike damaged diode. Nothing could be noticed until you applied power.
                        Smoked like hell. Package just fell apart
                        • kocoman
                          • Aug 2009
                          • 12
                          Does anyone have update for this?
                          • selldoor
                            Slow Learner
                            • 7870
                            Welcome to the forum
                            It quite unlikely - the post is over a year old!!
                            If you have a similar problem it is probably better to start a new thread
                            Please update your profile with Country and Mains Voltage
                            We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
                            Examples of what is needed
                            https://www.badcaps.net/forum/attach...1&d=1290283049
                            https://www.badcaps.net/forum/attach...7&d=1280167246
                            It will be useful if you can say what the supposed fault was and a bit about yourself - skills tools etc.
                            • MORETTIGIAN
                              Capacitor detached from PCB – RTX 2070 Super Founders Edition
                              by MORETTIGIAN
                              Title:
                              Description:
                              During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                              I did not notice it detaching, so I am unsure of its original location on the PCB.
                              Procedure performed:
                              - Removed backplate
                              - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                              - Reapplied thermal compound
                              - Reassembled card
                              Observed behavior after reassembly:
                              - GPU powers on and operates normally under...
                              09-18-2025, 12:14 PM
                            • nervous_capybara
                              Repairing the Hitachi DA-6000 CD player
                              by nervous_capybara
                              Hello everyone !
                              I recently conducted maintenance on a Hitachi DA-6000 CD player for my grandparents : it had two distinct issues.
                              Feel free to share your experience if you ran into other issues.
                              DISCLAIMER : BE VERY CAREFULL WHEN OPERATING ON THIS SYSTEM : THE HIGH VOLTAGE IS VERY CLOSE TO THE VARIOUS TESTING POINTS, PROCEED WITH CAUTION
                              CD tray would not come out of the player
                              I could hear a motor spinning inside the player but the CD tray would not come out.
                              Turned out that the issue was the CD tray belt that aged poorly and began to...
                              11-05-2025, 03:11 AM
                            • Prolog
                              RTX 3080 FE Identifying capacitor
                              by Prolog
                              Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                              I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                              I hope these photos make it clear which component I am referring to:
                              (yes, the soldering is a bit botched from removing the blown one, I know)
                              I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                              12-01-2024, 08:27 PM
                            • Agent24
                              Dick Smith Q-1760 linear power supply filter capacitor question
                              by Agent24
                              I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
                              It has at least one problem.
                              The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
                              I have already ordered a replacement potentiometer, so that's not an issue.
                              Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
                              All are CapXon...
                              10-21-2025, 05:39 PM
                            • chth96
                              If I replace with inferior capacitor, Is it No harm to other IC components at all?
                              by chth96
                              I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                              Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                              It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                              So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                              I know that these capacitor will not last as long as nichicon capacitor...
                              12-22-2023, 04:34 AM
