Help. Well first off I'm new at the cap replacment thing. I can do and I have do it for 2 motherboards and everything worked out fine. I have a lot of motherboards with what I believe to be cap problems and I will be contacting you guys to discuss purchasing so of your cap kits but what I want to know is how can I truely be sure that the cap is bad. These mobos have a lot of caps and I dont want to replace all of them. That would take forever. Other that the obvious simptoms and visuals how can I be sure how many and which caps are bad. I do have some electronic tools which I dont know really how to use a Tektronix tds 220 scope and a Fluke 867b Graphical MM and several other DMM's. Can these help me point out the baddies?
Help. I'm a newbie.
First of all, I would recommend replacing all caps 1000uF and up, even if you don't think they're bad. If others on the board of same brand and value have gone bad, it's just a matter of time for the rest. Replacing all will eliminate more headaches and aggrivation down the road! It really doesn't take too long to remove and replace a cap, far less than it would take to rip the system down again to correct oversights and goofs...
Honestly, I only break out the oscilloscope when I get a 'tough dog' repair. This is a board that I can't seem to get functioning again by simple methods. If you recap your board and it is still acting funny, thats when you want to get your scope and meters out to check for ripple and other abnormalities.
To be sure of bad cap problems, well if they're bulged and leaking gunk, you can be 100% sure that caps are your troubles. Let us know what boards you are working with, some are known for bad caps and won't show physical faults. Knowing the board might help....
TC<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team Stats -
kc8adu : server boards!!!! which ones? i nearly bought an old x series.Comment
Re: Help. I'm a newbie.
Since it's the only mention I see of the DFI CB61's, I have to ask if anyone knows for certain whether they were confirmed, affected by the capacitor plague. I'm close to doing a recap on a CB61, which is used in a Gannomat station, and the PSU, while a 250W, badged only as "KM" "Made in Korea", is equipped with all Nichicon's, and doesn't have a single bloated cap. But every single 8mm cap on the board is toast, even the lonely, 16V cap by the ISA slots!Presonus Audiobox USB, Schiit Magni 3, Sony MDR-V700Comment
I dont need to start a new thread about a board, which relates to only a single post on the entire forum. And since his query as to those specific boards did not get answered, it made sense to just being it up, again in the same thread. I know TC works hard to keep the forums streamlined.
I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.-
by qwerty99Hello!
I need to change the capacitors on my three original Xboxes.
Two of them are 1.6B revisions and have Hynix RAM, and the other one is a 1.6 with Samsung RAM.
The 1.6 has the infamous Nichicon HM capacitors around the CPU, which have all bulged and started to leak. This Xbox no longer powers on.
The 1.6B revisions have Rubycon MBZ capacitors that all look fine, but I’ll change them in due course. Both of these work fine.
I’ve seen some excellent threads on the forum about replacing/upgrading capacitors, but I can’t... -
by FoetussHi all
Hope this is in the correct place.
I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
Could use some double checking to see if I'm not doing something stupid
Pictures of the boards are attached.
What I will be replacing with what : (planned)
Soltek Golden ::
4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...2 Photos-
I would like to ask if there is some kind of capacitor lists for motherboards, power supplies, video cards, audio cards, microcontroller powered home appliances, and so, that i could try to find and download. I use to repair those things and i would find it helpful if i could know in advance what parts may i need for common repairs.
by blues_spiritHello from France,
mon2 kindly advised me to post a thread to ask the question(s) I'm concerned about. I'm new to the forum and I'm looking for practical courses for troubleshooting pc motherboards especially laptops in Europe, if possible in France. I have been a computer network system administrator and a corrector of administration modules for automated programs under Unix. But I really miss the practical "ops" side of troubleshooting. So I would like to start from the beginning: 1.8V, 3.3V, 5V and 19V tests for example, etc...
Do you think this is feasible for me? I... - Loading...
