bad cap in dell sx270
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    theres a bad cap ("c259") on a dell sx270 here at school (its one of those sff ones)... the cap is a rubycon 1500uf 6.3v...
    the original prob with this pc was that the ethernet wasnt working. but a different oc would nt work either, it turns out the ethernet cable was bad. so this one was put back, with a different ethernet cable. the computer is working fine (albeit a little slow with 256mb ram), and im wondering whether it matters that this cap is leaking its crap out. none of the others are bad looking, theyre mostly rubycons. this is right in the middle, between the ps and ram, near the agp solt, its theo nly one of its kind.
    since the computers working ok, does this need to be replaced?
    thnx!
  • seanc
    • Nov 2008
    • 1319
    Re: bad cap in dell sx270
    Common problem with SX270, they like to cook it also could have been a Rubycon from a bad date range.
    I swapped all of the Rubycons next to the CPU in one of my GX270 - one of them was leaking and they were in the 03 date code. Kind of rubbish considering the board was a replacement from Dell a couple of years ago.
    1800uf 6.3v Nichion HN are doing nicely.
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      Yeah i know these things are badly designed if they can fry rubycons
      As for my original question: even if it works, should the 1 bad cap get replaced?
      • seanc
        • Nov 2008
        • 1319
        It's not your problem, leave it to the IT guys.
        Hopefully they might replace it with a PC with more than 256mb RAM.
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          Lol dude im in cahoots with the it guy. More ram is going in when he finds his box of ram
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • Akhlz001
            by Akhlz001
            09-20-2025, 07:15 PM
          • master3112
            by master3112
            07-29-2025, 01:55 PM
          • F R 2568
            Dell Latitude 5420 does not start (no post) need help to find the reason why
            by F R 2568
            Hello all,
            this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
            I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
            If the laptop is only connected to the AC adapter (battery removed):
            When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
            The power/battery...
            01-08-2025, 05:45 AM
          • diamon
            Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
            by diamon
            I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
            Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
            Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
            Pictures of these boards:
            Dell Latitude 5520 https://www.ebay.com/itm/256052956663
            Dell Latitude 5530 https://www.ebay.com/itm/125844181534
            Dell...
            02-28-2024, 12:51 PM
