Cap Brand Check
  • davmax
    • Dec 2005
    • 899
    Cap Brand Check
    I cannot find the following listed in the bad catagory.
    CapXon and Xunda. Both brands are in a new 500W Power Supply just purchased.
    Input please. It is a little difficult to trust cap manufacturers at the moment.
    Gigabyte EP45-DS3L Ultra Reliable (Power saver)
    Intel E8400 (3000Mhz) Bios temps. 4096Mb 800Mhz DDR2 Corsair XMS2 4-4-4-12
    160Gb WD SATAII Server grade
    Nvidia 8500GT 256Mb
    160Gb WD eSATAII Server grade for backup.
    Samsung 18x DVD writer
    Pioneer 16x DVD writer + 6x Dual layer
    33 way card reader
    Windows XP Pro SP3
    Thermaltake Matrix case with 430W Silent Power
    17" Benq FP737s LCD monitor
    HP Officejet Pro K5300 with refillable tanks
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Cap Brand Check
    capxon is in many psu. Xunda is perhaps chinese company. you will not find nice brands in psu
    • davmax
      • Dec 2005
      • 899
      Re: Cap Brand Check
      I have now removed all capacitors in low ESR positions. 5 in all. They are all branded XJ nothing else. They are being replaced with Rubicon.
      The power supply is made by Delux and they quote 60,000 hours before failure. I do wonder how the caps figure in that number.
      It is interesting to visit the Delux web site search on (Delux power supplies). Low cost A$45.00 and good finish with large 120mm fan. Model DLP 388A.
      Nvidia 8500GT 256Mb
      33 way card reader
      Windows XP Pro SP3
      • PeteS in CA
        • Aug 2005
        • 3581
        • USA, Unsure of Planet
        Re: Cap Brand Check
        The 60K hours figure is probably a weighted average based on the reliability (source = vendor) of each component and the number of components, at some assumed load and ambient temperature. If (biggest 2-letter word in the English language) all components are good quality, properly chosen, the design is good, and the P/S doesn't get zapped by a huge lightening strike, the first component in the P/S to fail would probably be the fan.
        PeteS in CA
        • arneson
          • Sep 2005
          • 1267
          Re: Cap Brand Check
          When my power supply fan failed,
          it threw the power supply at me.
          Jim
          • Newbie2
            • Sep 2005
            • 885
            Re: Cap Brand Check
            What that the house fan with all those power supplies hung on the blades of it arneson?
            What brand of power supply was that?
            My gaming PC:
            AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
            ASUS M4A77TD AMD 770 AM3 Motherboard
            PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
            G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
            TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
            WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
            ASUS Xonar DG 5.1 Channel PCI sound card
            Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
            Antec Three Hundred Mid-Tower Case
            Microsoft Windows 10 Pro 64-bit
            Microsoft Windows 7 Ultimate SP1 64-bit
            • arneson
              • Sep 2005
              • 1267
              Re: Cap Brand Check
              Now you know who's nuts.
              Jim
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                Re: Cap Brand Check
                gotta invite you to one of our bsu parties.
                • Stanley1843
                  BEST 505 Vs Mechanic Brand Reballing Balls with Lead
                  by Stanley1843
                  has anyone use these Brands of solder balls? The brand BEST writes on the label of the jar the specs of the solder balls instead of the Mechanic brand. I beleive that BEST brand must be more professional (in labeling at least) but I have never try one of them so I would like your opinion. By the way I hardly can I find the Mechanic brand in aliexpress (the only where I found was lead free solder balls) and on ebay these that I found are approximately15USD per jar. If you know any other trusted brand of solder balls please tell me.
                  06-22-2024, 11:06 AM
                • dreico33
                  TL866 II Plus Check ID Error on various IC
                  by dreico33
                  Hellow guys , i really need your help here.
                  Lately i have a problem with My TL 866 II Plus programmer, and to be more specific many times on various IC ( Winbond, Gigadevice Mx) i get Check ID Error while i am trying to read the IC. Has already been detected without any kind of problem, but the only to read them is to uncheck every time the "Check ID " option. After that i can read it erase it and re-program it only to get another error at then end saying that can not verify the programing went well so i have program failed. So i am trying to find out what is going on? I...
                  11-04-2024, 03:13 PM
                • hasel17
                  CH341a can erase and read but can't write and blank check
                  by hasel17
                  So I am trying to repair broken thunderbolt FW on X1 Yoga Gen 2. The EEPROM chip is WINBOND 25Q80DVNIG. I already do a back-up and erase. But when I try to wrote new FW, it was successfull, but when I tried to read it, it still blank. when I try to do a blank check, it gave me instant error in address 0. I already tried two CH341A, already did the 3.3v fix mod, using AsProgrammer, NeoProgrammer, Colibri, and CH341A 1.29. But the problem still occurred. What I did wrong here? Can anyone help me? Thanks in advance. Here is the log in Colibri :
                  Code:
                  Checking for blank...
                  (Press
                  10-26-2023, 06:20 AM
                  HP Pavilion 15-cx0198tx Notebook 15 Specification for Upgrade or Repair
                  This specification for the HP Pavilion 15-cx0198tx Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15-cx0198tx boardview and 15-cx0198tx schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                  09-06-2024, 09:17 AM
                  HP Spectre x360 13-ae511tu Hybrid (2-in-1) 13 Specification for Upgrade or Repair
                  This specification for the HP Spectre x360 13-ae511tu Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 13-ae511tu boardview and 13-ae511tu schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                  09-06-2024, 06:27 AM
