Imac capacitor help
  • thenoicer
    • Jun 2018
    • Sweden
    Imac capacitor help
    Help with capacitors
    Hey, im fixing a imac logic board that has a damaged capacitor. The original capacitor says: 947 Sepc 270 16. I have looked through board viewer and traced it to the correct values: 270uf, 16v. Just as the original capacitor says. I cant find a direct replacement online for this capacitor. I have 239 Sepc 270 16 capacitors laying around, and compared to the original it's smaller. But is also 16v, 270uf. Can i replace it with this one? I cant really find specifications for them. Thanks
    • 31304
    Re: Imac capacitor help
    SEPC is an early polymer cap from sanyo,
    nichicon , panasonic and kemet among others also make good polymers
    the other number doesnt mean anything really, just gonna be a batch/date code
      master hoarder
      • May 2008
      • 12175
      Should work fine.
      SEPC = Sanyo SEPC polymer capacitor series.
      Datasheet here:
      Code:
      http://www.paullinebarger.net/DS/Sanyo/Sanyo [polymer thru-hole] SEPC Series.pdf
      (Copy and paste link into browser. Can't direct-link, because the square brackets upset the forum's auto-URL code.
      • MORETTIGIAN
        by MORETTIGIAN
        Title:
        Description:
        Procedure performed:
        - Removed backplate
        - Reapplied thermal compound
        - Reassembled card
        09-18-2025, 12:14 PM
      • LaPCon_IT
        iMac A2438, destroyed capacitor and coil.
        by LaPCon_IT
        Hi people.
        iMac A2438, board 820-02009-06. Some insect has killed itself destroying capacitor and coil next to it. No chance for buying donor board, so I'm asking you for help about values of destroyed components.
        03-16-2024, 09:32 AM
      • devsigner
        identify capacitor for MacBook Pro with rare logic board 820-02037-06
        by devsigner
        Hi
        While messing around with my MacBook Pro, I stupidly pinged off a very small surface mounted component that I’m now trying to identify.
        resistance tests show a rising resistance value, indicating a capacitor.
        The laptop boots up and runs, however I'm choosing not to use it until I get it fixed.
        i can’t see any markings on the capacitor at 10x magnification using a professional jewler's loop.
        It seems like there's some damage to the capacitor - one side doesn't have "shiny bits" - can you tell I don't do this for a living!...
        Yesterday, 01:39 PM
      • Prolog
        by Prolog
        12-01-2024, 08:27 PM
      • Agent24
        Dick Smith Q-1760 linear power supply filter capacitor question
        by Agent24
        I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
        It has at least one problem.
        The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
        I have already ordered a replacement potentiometer, so that's not an issue.
        Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
        All are CapXon...
        10-21-2025, 05:39 PM
