Thomson capacitors - looking for datasheet
  • Olkus
    • Aug 2023
    • 11
    • Poland
    I can't find anything about this caps - maybe someone have a datasheet?
    And are they good quality?
  • andrewsawesomr
    • Jun 2022
    • 110
    • United States of America
    • Coding, Electronics, Music
    Re: Thomson capacitors - looking for datasheet
    Photos?
    • Olkus
      • Aug 2023
      • 11
      • Poland
      Photos are attached. The top is similar to Partsnics and Daewoo caps.
      • dragon3x
        by dragon3x
        power on.
        Here are some examples :
        switching supply area).
        than 6.3 V.)
        03-21-2025, 02:46 PM
      • mario_split123
        PCChips/Hsin Tech M537 V3.1 Old motherboard capacitors
        by mario_split123
        Hello everyone !
        I am new to this forum and also a begginer/hobbyist in electronics. I have a question about an old AT motherboard model PCChips/Hsin Tech M537 V3.1. It hasnt been powered on for 30 or so years.
        I have read that it is not safe to power it on after such a long time because capacitors can suddenly burst. When I inspect capacitors I cant notice any visible damage,leak,corrosion or bulged capacitors.
        What are your suggestions ? Replace all capacitors maybe or ?
        Thank you in advance for your answers !
        02-17-2026, 07:18 AM
      • BlackScreen_22
        Harman Kardon sub TS11 (ds15 amplifer) blows fuse and mosfets
        by BlackScreen_22
        Hi, I'll start by saying that I'm not an expert and I've reached a point where I don't know what to try/do anymore...
        Starting from the beginning: I opened this subwoofer for the first time with a very strong smell of burnt electrical components, I realize that on the amplifier board there is a hole between V+ OUT and GND about the size of a finger, the damaged components were the shorted mosfets, two damaged zener diodes and two capacitors. I bought everything, I fixed the hole by cutting the pcb and putting a piece of a perforated board.
        I had no problems connecting mosfets and capacitors,...
        08-27-2024, 12:46 PM
      • AlexVG
        JBL PARTYBOX 1000 NO sound NO 50V
        by AlexVG
        Hi, I would like to share my experience...
        So, I came across with common problem - no 50V on PSU 40-PF0750-PWD1G
        L6566B was burned. Between pin 7 and GND were short circuit. I replaced L6566B with a new one, but it gave me nothing. However, it started if I touched pin 16 with multimeter probe. Obviously the protection is triggered.
        If we look at the L6566B datasheet, we will see that to deactivate the protection (AC_OK), is enough to exceed 0.450 volts.
        In my case, I have had 0.632 volts. This is enough at the first glance. But on the oscillogram on pin 16, I observed noise...
        03-11-2025, 06:55 PM
      • slybunda
        AA and AAA battery charger capacitors?
        by slybunda
        hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
        it has inside:
        2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
        2 x 470uf 16v LZ105c branded as G.Luxon
        not heard of these brands are they any good?
        iv attached photos of the charger and the board inside for an idea on the type of...
        12-24-2023, 04:41 AM
