Elna capacitors - fake?
  • Olkus
    • Aug 2023
    • 11
    • Poland
    I have capacitors like this one in the photo. There are differences between other Elna series, I attach foto of Elna RE3. On this green capacitors series is not specified! Fake?
    • 31063
    Re: Elna capacitors - fake?
    it's old - atleast if the datecode is real.
    why does the vent have dirt in it?
    is the top even flat?
    • Olkus
      • Aug 2023
      • 11
      • Poland
      The top is OK, no dirt in the vent. Parameters are good, capacitance (all 100 pcs) is 47uF>, ESR about 1R.
        • 31063
        1ohm sounds high
        • Olkus
          • Aug 2023
          • 11
          • Poland
          Originally posted by stj
          1ohm sounds high
          I think it's not bad for 47uF 16V, not Low ESR. I've compared with other parts with the same parameters, and the results are similar.
            • 31063
            you say it's not low esr, but it is 105' temp rated.
            • Olkus
              • Aug 2023
              • 11
              • Poland
              1ohm is too much for this caps? I don't have datasheet so is not possible to check.
                • 31063
                i looked at a bunch of random datasheets for 105' but average esr caps
                rubycon YXF for example is 0.9ohm
                  master hoarder
                  • May 2008
                  • 12175
                  • Bulgaria
                  +1
                  For small caps in 5x11 size, 1 Ohm at room temperature is not abnormal at all... even for low ESR series. For GP (non-low-impedance) caps, even up to 2-3 Ohms may be OK, depending on room temperature and age of the cap. In any case, 2-3 Ohms still not considered out of spec.
                  BTW, the light-green Elna might be a low-leakage type cap. A lot of older light-colored sleeve caps were typically low leakage type meant for audio circuits / signal coupling.
                  • Olkus
                    • Aug 2023
                    • 11
                    • Poland
                    Thanks for your answears.
                    Probably you are right. This caps are bigger than my other caps with the same parameters. And I compared with many photos on internet, and I think they ae not fake. But I'm still not one hundred percent sure.
                    • Ady2017
                      Are there any datasheets available for Elna RJG capacitors?
                      by Ady2017
                      I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
                      05-25-2025, 02:19 PM
                    • dragon3x
                      After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                      by dragon3x
                      Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                      power on.
                      Here are some examples :
                      (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                      switching supply area).
                      (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                      than 6.3 V.)
                      1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                      I replaced capacitors with aluminum-polymer.
                      3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                      03-21-2025, 02:46 PM
                    • slybunda
                      AA and AAA battery charger capacitors?
                      by slybunda
                      hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                      it has inside:
                      2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                      2 x 470uf 16v LZ105c branded as G.Luxon
                      not heard of these brands are they any good?
                      iv attached photos of the charger and the board inside for an idea on the type of...
                      12-24-2023, 04:41 AM
                    • Hitto
                      Fake Nichicon capacitors with almost-perfect sleeve?
                      by Hitto
                      Fake Nichicon capacitors with an almost-perfect sleeve?
                      Same font, perfect logo, same size of the sleeve. The air vent looks okay. The diameter of the capacitors is correct per datasheet.
                      It truly looks like the real thing.
                      I doubt that you would distinguish it from a genuine one.. if it wasn't for the bung.
                      Shall we be afraid, at this point, that even the bung can be replicated?...
                      01-09-2021, 03:07 PM
                      by sam_sam_sam
                      After all of...
                      07-13-2024, 08:14 PM
