Need help identifying replacement caps
  • jondilly1974
    • Nov 2009
    • 38
    Hi all!
    I have a Magnavox 15MF605T/17 LCD Monitor that has two blown caps on the power input board. They are:
    Capxon SZ 150uF, 25V, 8x7mm, 340 ripple, .40 impedence, 105C
    Tried tracking down a replacement via Digikey search, but not having any luck. Any help you guys can give would be super appreciated!
  • yyonline
    • Jul 2009
    • 692
    Re: Need help identifying replacement caps
    Chemicon LXY is the closest I could find on a very quick search. It's taller than the original, but same diameter so the leads should line up... 8x12 vs 8x7. So be sure to check for any clearance issues. It's also slightly better for ripple and impedance.
    http://search.digikey.com/scripts/Dk...me=565-1792-ND
    • jondilly1974
      • Nov 2009
      • 38
      Thanks for the help.
      Height should not be much of an issue. I have plenty of clearance.
