This can't be real
  • pentium
    • Mar 2006
    • 2778
    This can't be real
    Spotted this on an Intel 775 board. It's the only one that has popped.
    I thought Nichicon were ok caps? Just a random bad one?
    Find Nedry!
    Check the Vending machines!!
    <----Computer says I need more beer.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    Re: This can't be real
    Whats the date code on it?
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      Lol yeah my intel 955 chipset voard has nichi hm with an 04 datecodes. But they never got a chance to fail cuz my lousy psu fried it.
      • pentium
        • Mar 2006
        • 2778
        If it's still on the bench tomorrow morning I'll get back to you.
        Where should I find the date code? Other side of the cap?
        Find Nedry!
        • c_hegge
          • Sep 2009
          • 5219
          It usually look something like H0422 (2004, Week 22). Nichicon HM and HN had manufacturing defects which they fixed on 2005, so if the date code is 2005 or older, then that might explain why it failed
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • Romania
            That looks just like the blown Nichicon HMs that i have right here, i'm 90% sure it's the same cap. So it's from the faulty series.
            A working TV? How boring!
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              The board also has Nichicon VR series which are 85C and can be a problem in poorly cooled systems.
              Even the small 4mm & 5mm fail.
              Mann-Made Global Warming.
              - Dr Seuss
              • pentium
                • Mar 2006
                • 2778
                The cap is marked for "H0510", or 2005, week 10.
                Find Nedry!
                • seanc
                  • Nov 2008
                  • 1319
                  It's next to a mosfet, which may get very hot. Checked the PSU?
                  I have a slew of ASUS 945 boards being "destroyed" by bad ASUS branded Delta PSUs. There's one particular KZG cap that cooks next to a mosfet - meaning the SATA controller stops working
                  I'm pretty sure the faulty PSU caps causes the mosfet to get very hot, cooking the KZG cap.
                  Maybe something similar has happened to you?
                  Edit:
                  I'm pretty sure the Nichions I pulled out of my SX280 were 05 dated. One had baked, but it is a hot box in there.
                  • shovenose
                    Send Doge Memes
                    • Aug 2010
                    • 6575
                    You had a fault asus psu? I need to know about that. Bexuase i have one. And i consider it high end becuae its really heavy and has good 12v ratings for 300w. Is the 300w asua the one you had tha was faulty?
                    • seanc
                      • Nov 2008
                      • 1319
                      I don't have one, I have four. Five, if you count the first one I threw out, thinking it was a one-off dud.
                      Open it up and check!!
                      There is a very tall, slim Capxon 2200uf 6.3v cap that usually failed.
                      There is also another one that has failed in some, think it may be a 2200uf 16v - can't remember exactly.
                      • shovenose
                        Send Doge Memes
                        • Aug 2010
                        • 6575
                        Was it 300w?
                        • seanc
                          • Nov 2008
                          • 1319
                          I believe it says it'll peak at 300w.
                          *Traipses off to garage to check*
                          • Krankshaft
                            • Jan 2007
                            • 2328
                            I love how cheap PSU manufacturers use that term to deceive people not in the know they see the wattage and ignore the peak after it.
                            So 300W for a few milliseconds before it lets out the magic smoke. Since most of these crap supplies don't have over current protection.
                            Where between 300W and 1W is the continuous rated wattage? We will never know probably the engineer at Wan Hung Lo corporation who made it doesn't know either. I'd fathom a guess it's between 150W and 200W.
                            But if they put the REAL continuous rating on the PSU nobody would buy it since it's not the 90s anymore .
                            • seanc
                              • Nov 2008
                              • 1319
                              I was right, it does say it 300w peak
                              • shovenose
                                Send Doge Memes
                                • Aug 2010
                                • 6575
                                Mine actually says asus in big letters imprinted on Its casing. And it has bigger heatsinks. And it has an 80mmfan on the end not the 120mm on the "bottom"???
                                • shovenose
                                  Send Doge Memes
                                  • Aug 2010
                                  • 6575
                                  I have verified that my psu is different. It has jamicon secondaries, bigger heatsinks, more density, etc. It also said bestec on of the transformers. So its really a decent psu. Asus s-30fp.
                                  • 370forlife
                                    Large Marge
                                    • Aug 2008
                                    • 3113
                                    post pictures of that bestec built asus. I have been trying to find one for a long time now.
                                    • PCBONEZ
                                      Grumpy Old Fart
                                      • Aug 2005
                                      • 10661
                                      OH COOL!
                                      You might get 300W for a FULL SECOND before it lets out the magic smoke!!
                                      - Dr Seuss
                                      • 370forlife
                                        Large Marge
                                        • Aug 2008
                                        • 3113
                                        Bestec power supplies can be pretty solid units. 300W is not that hard to achieve. About 70% of those 500-650W off brand chinese psu's are based off of 300W platforms that some little company in china designed with their highly trained staff of two engineers.
                                        • AdrenalinTL
                                          Macbook Pro A1707 - Dead - Battery 'popped'
                                          by AdrenalinTL
                                          Hi Peeps.
                                          Just a quick question please as I am by no means an Apple fundi at all.
                                          Can a 'popped' battery cause the Macbook to be completely dead? Client said the battery definitely popped. It doesn't look swelled or anything but it doesn't switch on at all. No lights, no fans, nothing.
                                          Also, using a 85W original Apple charger. That is working for sure. Does it need more wattage?
                                          Don't want to go buy a battery for no reason.
                                          Client is adamant is worked before the battery popped and I can't see any damage what so ever on the board...
                                          07-18-2024, 09:52 AM
                                        • EvazX
                                          ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
                                          by EvazX
                                          I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
                                          Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
                                          For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
                                          However, after some time, the replacement motherboard...
                                          08-25-2025, 06:09 PM
                                        • Prosatanosz
                                          Asus B85M-GAMER no hdmi output and random restarts
                                          by Prosatanosz
                                          Hi!
                                          Asus B85M-GAMER absolute no hdmi output (not at start, not at Windows), and random restarts. Everything work, except hdmi and random restarts after 0.1-3 min. Restarts even in bios. On VGA Windows boots up fast, games and apps starts ok. Mem, psu, cpu changed, no luck. I need shematic, because i think the restarts caused by the hdmi failure.
                                          10-19-2024, 05:27 AM
                                        • cnti
                                          Samsung 245B PLUS - BN44-00195A - bang and smoke - solved - tips
                                          by cnti
                                          Hi.
                                          BacCaps forum is awesome - thank YOU ALL for sharing knowledge!
                                          This is about DONG YANG PSU BN44-00195A failiure in Samsung 245BPLUS. It started with bang and smoke from the back of LCD. Downloaded diagram BM44-00192A - a bit different but I will use all parts names from this diagram [and real PSU].
                                          BIG CAP CP801 had 315V, on standby pin 5,2V. After shorting S_B ON (through 3,3k ohm resistor) 24V and 5,3V were missing, on CP801 was 312V.
                                          RM801 [real PSU: RM801 - 0,22 ohm 1W] - FAIL
                                          burned, measured 10M ohm.
                                          QM801 [real PSU:...
                                          10-19-2023, 05:33 PM
                                        • Dreigas
                                          Asus TUF Gaming FX506LX laptop just stuck at random time
                                          by Dreigas
                                          I've got a problem with my Asus TUF Gaming FX506LX laptop. I bought it as a non-working unit it had been completely drenched in a sweet alcoholic drink and was left for a year... When I got it, the motherboard wasn't in terrible shape, but I had to clean a lot of areas—about 1/5 of the motherboard. There was some corrosion, but I managed to clean it up and re-soldered where I saw issues under a microscope.
                                          One of the two primary MOSFETs was fried (PQ33 fried and PQ34 were fine), so while I was waiting for a replacement, I desoldered it and created a short....
                                          07-27-2024, 05:58 AM
