Capacitor help please.
  • Aknot
    • Sep 2010
    I am looking for a capacitor by Rubycon the part number I have been given is a,
    6.3MCZ1800M8X20
    Rated Voltage 6.3
    Capacitance 1800uf
    Tolerance 20%
    Temp Range -40 to 105c
    Rated Ripple current 2350
    ESR12
    Diameter 8mm
    Height 20mm
    K vent on Top
    Through Hole 2 pin.
    I have searched everywhere and I did come close but the Rated ripple Current was different and so was the Height and Diameter, but could I get away with trying any of the two capacitors that I was lead to believe may be ok.
    I went to a website called farnell in the UK and did a product search for,
    1744874 and 1800609
    Would they be any good?
    I could basically cry because Im so sick of searching, lol.
    Thanks Guys for any help given.
  • MXM
    • 430
    • Unknown
    Re: Capacitor help please.
    i think i read in other post around that the MCZ series was an OEM series, but, i a m not sure.
    if you are tryin to replace a low esr cap with those specs i guess u could get it rubycon or not... about those u asked, i dont know their specifics but if they are 1800/6.3 and low esr then i guess they are good, as long as they fit...
    also, im not good on advises on this issue, you may want to wait for better replies.
    peace.
    We don't have a great war in our generation, or a great depression, but we do, we have a great war of the spirit. We have a great revolution against the culture. The great depression is our lives. We have a spiritual depression.
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      MCZ is not OEM only. - I think you are thinking of MFZ.
      The Electrolytic caps with ESR that low or better are:
      Rubycon MCZ [obviously]
      Samxon GC or GA Series
      Nichicon HN or HZ Series
      Chemicon KZJ is also but KZJ have heat issues. [Don't use them.]
      Mann-Made Global Warming.
      - Dr Seuss
      • retiredcaps
        • Apr 2010
        • 9271
        6.3MCZ1800M8X20
        This part number comes from thecapking.com. Badcaps.net has these as well, but they are completely sold out and won't have any for the next couple of months (see badcaps.net - announcement right on the front).
        --- begin sig file ---
        --- end sig file ---
        • Aknot
          • Sep 2010
          Thanks for the replies guys, in my first post I mentioned farnell and the part numbers would these caps do I need the specific ones I already have.
          I just noticed the announcement, thanks for the info.
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Aknot
            Edit your profile and put in you location. [At least the country.]
            It helps for questions like this.
            - Dr Seuss
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Farnell gives you a link to the data sheets.
              Look at Ripple, more [bigger number] is better.
              Neither of those Part numbers are as good as MCZ.
              - Dr Seuss
              • MORETTIGIAN
                by MORETTIGIAN
                Title:
                Description:
                Procedure performed:
                - Removed backplate
                - Reapplied thermal compound
                - Reassembled card
                09-18-2025, 12:14 PM
              • chth96
                Is it no harm to replace with capacitor without ripple current rating?
                by chth96
                When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                Rubycon YK DataSheet (b...
                04-19-2024, 05:19 AM
              • quickname
                Cyberpower 1500AVR UPS repair
                by quickname
                I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
                I decided to verify that the batteries were...
                11-12-2023, 09:57 AM
              • Per Hansson
                Repair of Sign WiFi Smart Plug PCB: SA-P302A v1.2 due to bad caps - with schematic
                by Per Hansson
                I have repaired a Sign WiFi Smart Plug with model number: SNSM-WASINGLE sold by Spares Nordic AB in Sweden.
                The fault condition was that the device gave no signs of life: pressing the push button did not cycle the internal relay and the blue LED did not come on and it was not seen on the WiFi network.
                The fault was very simple, capacitor C3 on the PCB with writing "KSJ" and "LOWESR" had literally blown its top off, after replacing it the device works fine again!
                As I find linear high voltage regulator designs interesting I drew up the attached schematic...
                12-23-2023, 06:20 AM
              • Agent24
                Dick Smith Q-1760 linear power supply filter capacitor question
                by Agent24
                I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
                It has at least one problem.
                The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
                I have already ordered a replacement potentiometer, so that's not an issue.
                Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
                All are CapXon...
                10-21-2025, 05:39 PM
