leak or glue?
  • hinisa
    • Apr 2021
    • 19
    • turkey
    leak or glue?
    hi. psu works, but it was loud and filthy so I opened the case to dust it.
    2 caps in the picture has a transparent yellow stuff on top of them but I'm not sure if they leaked or it's some kind of glue.
  • R_J
    • 9514
    Re: leak or glue?
    That is glue, remove the glue from the one next to the coil to see if it is bulged under the glue, if the top is flat it is likely ok but you can not tell just by looking.
    What was loud? noisy fan?
    • hinisa
      • Apr 2021
      • 19
      • turkey
      Re: leak or glue?
      1, 2: Conicon 1009 - 1000uf 10V Low ESR
      3: Conicon 1005 - 1000uf 10V
      (1) and (3) looks slightly bulged, 2 isn't.
      I bought 2 no-name 1000uf25V caps from local store but I'm not sure they'd be fit as low esr replacements.
      Also wondering if I can install something in place of C42 which was left empty in factory.
      yes, fan runs very fast and loudly. If I can't find a silent replacement fan I'm thinking of undervolting it by splicing from the 5V line.
      • hinisa
        • Apr 2021
        • 19
        • turkey
        Re: leak or glue?
        Found an analysis of the psu here: https://www.overclock.net/threads/li...ld-fly.769505/
        • R_J
          • 9514
          Re: leak or glue?
          Yes those two caps are bulged, and are bad, that is usually due to being close to the inductor that will run fairly warm, The cap at location C42 is likely parallel to one of the other caps, and not required. You may want to replace those two small electrolytics next to the coil as well, they won't bulge like the others but will just dry out from the heat.
          • PeteS in CA
            • Aug 2005
            • 3576
            • USA, Unsure of Planet
            Re: leak or glue?
            The cap you labeled #1 is next to an inductor that could get hot and a pre-load resistor that is also dissipating heat. I suggest leaning the resistor a bit farther away from the cap.
            Since L4 and L5 have been replaced with jumpers, that P/S probably has very poor spike noise. I recommend looking on the primary side at the capacitors Line-to-chassis and Neutral-to-chassis. If they are there, they should be safety agency approved parts. If they are rated for 1 KV or 2 KV DC, that is a safety problem.
            Glancing through that linked review, calling it a turd may be an insult to turds. The review sample had the dangerous DC rated Line- and Neutral-to-chassis - "Y" - capacitors. If the primary side capacitors really are 470uF, they might be adequate for 250W. The MJE13007-clone transistors and heatsinks might be adequate for 250W. It sounds like the main transformer is small for 250W, though, so 200W would be a more realistic maximum continuous output power.
            Safety agency approved Y capacitors could replace the cheapies, 560uF or 680uF capacitors could replace the 470uF types, the switch transistors could be replaced with MJE13009-clones, more honestly rated output rectifiers could replace what is there, good quality output capacitors could replace the Canicons, and ferrite rod inductors could replace the jumpers at L4 and L5, but the main transformer would still limit the realistic continuous output power to ~200W.
            PeteS in CA
            • Per Hansson
              • Jul 2005
              • 5895
              • Sweden
              Re: leak or glue?
              I always wondered why the Chinese do this, who do they just not skip installing capacitors there at all, have they not heard of Muntzing?
              Is it a game to try to make the device as dangerous as possible?
              Certainly when you watch some videos from Big Clive you might start believing so...
              • hinisa
                • Apr 2021
                • 19
                • turkey
                Re: leak or glue?
                Here I present CY1
                I'm starting to think maybe it's better if I'd re-assembled this without any recap and only use it as power source for the tire inflator from now on
                • Per Hansson
                  • Jul 2005
                  • 5895
                  • Sweden
                  Re: leak or glue?
                  Originally posted by hinisa
                  Here I present CY1
                  What happened, is it corrosive glue or has the capacitor shorted?
                  Using ceramic caps for this type of circuit is just insane!
                  I'm genuinely interested if someone can answer the question in my previous post!
                  • hinisa
                    • Apr 2021
                    • 19
                    • turkey
                    Re: leak or glue?
                    it has only 1 leg left other one looks burnt. psu still works splendidly, though.
                    • Per Hansson
                      • Jul 2005
                      • 5895
                      • Sweden
                      Re: leak or glue?
                      Yea now I see it, there is one behind it that appears to have exploded too.
                      This is a prefect example why safety rated capacitors are required here.
                      But also why it is so idiotic to put regular ceramics: they can just be left out and the thing will work fine anyway!
                      Chinese crap.
                      • PeteS in CA
                        • Aug 2005
                        • 3576
                        Re: leak or glue?
                        A PWS can work OK without all those common mode inductors, X caps, and Y caps, but other electronic products, like TVs and radios, might be affected by conducted EMI.
                        PeteS in CA
                        • Per Hansson
                          • Jul 2005
                          • 5895
                          • Sweden
                          Re: leak or glue?
                          I know I know, but you think these Chinese seller test for conducted EMI before putting the thing on the market? Lol of course not!
                          Here is a link hinisa for proper safety rated capacitors.
                          But you should check that they have the correct lead spacing, and also capacitance rating.
                          But it gives you an idea what they should look like
                          https://www.digikey.com/en/products/...2M-VKA/6124900
                          • aidanmo
                            Philips 43PUS7506/12 - Loud blown out sound
                            by aidanmo
                            I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                            I thought maybe the speakers got damaged, so I replaced them - no dice.
                            • Using the internal speakers, it always happens.
                            • Using the headphone jack, it never happens.
                            • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                            02-28-2025, 03:13 PM
                          • acedogblast
                            by acedogblast
                            11-02-2024, 05:13 PM
                          • mitsu2k
                            The Real Dangers of conductive glue.
                            by mitsu2k
                            I know many folks on this forum warn against conductive glue and suggest removing it immediately upon site. I'm here to vouch and say these people know what they are talking about. To be more accurate, the glue isn't intended to be and doesn't actually start out conductive. It gets conductive as it is heated by components that get hot. The glue starts out to be a light tan color but as it is exposed to heat, it gets darker and darker until it is a dark brown. I have found that it becomes conductive at the point that it reaches a light brown color on darker.
                            Here is an experience I...
                            04-16-2023, 06:29 PM
                          • digtalhd
                            Remove IC glue
                            by digtalhd
                            Hi!
                            Anybody help me. Remove IC glue on mainboard.
                            Thank you....
                            11-08-2024, 02:25 AM
                          • justice171
                            Lenovo E15 Gen 2 Keeps Beeping Loud Noise
                            by justice171
                            Hello Badcaps Members,
                            I'm experiencing an issue with my Lenovo ThinkPad E15 Gen 2, and I'm hoping someone here might have some insight. The laptop charges to full capacity, but as soon as I power it up, I get a loud sound, and there's no POST.
                            I disconnected the battery and connected a USB meter, which shows 20V 0.23A when the sound occurs. I've already tried changing the screen, but it didn't resolve the issue.
                            When I use Lenovo PC Diagnostics App I get results as 01000
                            Here are the details:
                            • Model: Lenovo ThinkPad E15 Gen 2
                            • Board Numbe
                            10-01-2024, 09:19 PM
