3300uF 6.3v Capacitors Needed!
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    I'm trying to track down some 3300uF 6.3v low-ESR capacitors for a Biostar Socket 423 motherboard. The problem is, all my 3300uF caps are 12.5mm diameter, and I need 10mm... Even Digikey or Mouser doesn't have 10mm 3300uF caps. If any of you know of a source or have any 3300uF caps, let me know!! Their height isn't a big issue, just the diameter.
    TC
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
  • stretch0069
    Screwed Up Super Moderator
    • Oct 2003
    • 2658
    • oooo ess aaaaaaaaa
    I ran across a place that had odd components. i'll try to track it down for you by the weekend.
    "Its all about the boom....."
    Guns kill people like spoons made Rosie O'Donnell fat.
    We now return you to your regularly scheduled drinking.
    "Fear accompanies the possibility of death.....calm shepherds its certainty"
    Originally posted by Topcat
    AWD is just training wheels for RWD.
    • stretch0069
      • Oct 2003
      • 2658
      Whew....I still had the list in an old doc.
      Here's the bad news.......I don't know if they have what you need. The good news is, they either can make it or know what obscure place does have it. I was looking for the exact replacement for the 1500s on the VP6. One of them replied with where to get it. Just can't remember which. Sorry I couldn't be of more help.
      www.electrocube.com
      www.globalspec.com
      www.capacitorindustries.com
      www.niccomp.com
      www.illcap.com
      • stretch0069
        • Oct 2003
        • 2658
        Figures..... :roll:
        As soon as I hit 'Submit', I remembered this site I used to go to when I was purchasing parts for some boards I was building.
        http://www.freetradezone.com/
        It requires registering, but if I remember correctly, you can register with whatever names you want.
        I never looked for low ESR caps, but had a search engine.
        Lets see if I can further the confusion factor...... :roll:
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16958
          I found a place that can get Rubycon mini caps... I about dropped the phone when they told me the prices though... $1.77 each for 200 or less!! sh*t!!!!!
          I'll check your leads out, and thanks!
          Team : 49813
          Join in!!
          Team Stats
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            too bad its so tight.
            i have plenty of 3300@10 rubycon yxg i got cheap.
            iirc they are 14mm
            • Ark42
              • Apr 2004
              • 43
              So whats the verdict on the 6.3v 3300uF 10mm? The Epox 8RDA+ uses 6 of these in a row, and I'm not sure 12.5mm would work. I was thinking of leaning 3 one way and 3 the other way if I really had to replace them. mouser.com was backordered on the 12.5mm ones anyway so I didn't order them.
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                i havnt needed any that size yet.
                i have always found a way to use what i had on hand.
                might be tough to find that size from a reputable mfr.
                i once used smaller values that would fit and put large smt tantulums in paralell on the bottom of the board.
                seemed to do a good job of keeping vcore clean.
                • KoolBreeze
                  • Jun 2004
                  • 4
                  yet another needs same
                  I also need a single cap of this rating and size.
                  any luck so far finding such a beast?
                  one single 3300uf 6.3v 10mm dia and one single 1500uf 10v 8mm dia are needed to repair a Soyo SY-6BA+100
                  can't seem to find either type anywhere. :?
                  • KoolBreeze
                    • Jun 2004
                    • 4
                    this brings teh suck.
                    now what? RMA a stinking board that would take a couple minutes to replace 2 lousy caps?
                    nevermind paying for it and associated hassle.
                    • Topcat
                      The Boss Stooge
                      • Oct 2003
                      • 16958
                      I FINALLY FOUND SOME!!!
                      YES!! I found some Rubycon Ultra low-ESR 3300uF 6.3v caps in a 10mm diameter!! They were ungodly expensive, but I've got a few if anyone needs them.
                      Team : 49813
                      Join in!!
                      Team Stats
                      • KoolBreeze
                        • Jun 2004
                        • 4
                        oh? ok, so a bit ot perhaps, but any 1500uf 10v 8mm?
                        • kc8adu
                          • Nov 2003
                          • 8832
                          • U.S.A!
                          better replace all the 1000> mfd low esr caps.
                          i am running a 6ba that was full of wendel? caps that were all bad even though they were not all bulging.
                          since all the ones along the slot are in paralell i installed 3300@10 in every other space.vcore is dead clean on the scope.
                          • KoolBreeze
                            • Jun 2004
                            • 4
                            makes sense while "I" am doing the work, but if I DID rma the board you know Soyo would only replace the two bad ones.
                            I'm thinking all the ones running alongside the cpu slot are 1000uf but I won't be able to verify until later.
                            the two needing replaced are a side by side pairing off to the side standing seperate from any others.
                            I've tried a few sources to locate those and have even contacted Soyo to see if I could purchase a couple from them but they want me to RMA the board. :?
                            • kdr9232
                              • Dec 2004
                              • 3
                              thats interesting my ga-7dpxdw mobo neads 20 3300uf 6.3 volts caps where to get them at ?
                              • bushytails
                                Moderator
                                • Dec 2004
                                • 217
                                If you can fit 12.5mm caps, you can get them lots of places, and reasonably cheaply... if you need 10mm ones, better wait for topcat to reply with where he got his.
                                The (ugly) option is to use 12.5mm ones, with long leads, and stagger them. i.e. squish one to the right, one to the left,... I don't know how well that will work on your board though, having never seen one.
                                Another ugly option is to buy extra-large caps (I've seen 12.5mm 5600uf ones, can get much higher if you can fit 16/18mm), and put them in every other spot, assuming they're all in parallel.
                                (oh, and if you decide not to recap the board, I'll happily relieve you of it.
                                --Randy
                                • quickname
                                  Cyberpower 1500AVR UPS repair
                                  by quickname
                                  I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
                                  Like clockwork, I've had to replace the SLA batteries every 4 years. It was about that time and the UPS was acting like it needed new batteries... randomly shutting off with AC present, not being able to charge fully, and poor runtime when AC was removed. So, I replaced the batteries but noticed that it was not charging properly.
                                  I decided to verify that the batteries were...
                                  11-12-2023, 09:57 AM
                                • ssl6
                                  MSI K7T266 Pro (Ver. 1.0)
                                  by ssl6
                                  Hey Everyone,
                                  Long time lurker, but I think this is my first time posting.
                                  Just looking for some assistance on identifying some suitable replacement capacitors for an MSI K7T266 Pro (Ver. 1.0). I just got my hands on two of them actually, both working but one has some visibly bulging capacitors and the other has a few that I can't tell for sure if they're bulging because it's faint at best if they are.
                                  I'll be honest I don't fully understand much on capacitor spec sheets beyond voltage and capacitance but I can solder like nobodies business so I've...
                                  11-09-2023, 01:00 PM
                                • CWEastwood
                                  Antec Smart Power SL300S capacitor replacement.
                                  by CWEastwood
                                  I'm currentlly in the process of trying my first power supply repair (really my first soldering project) and have some questions with regard to which capacitors to replace the bad ones.
                                  The power supply is an Antec Smart Power SL300S ATX12V 300 watt.
                                  I have successfully desoldered every capacitor from the board without destroying anything (I think) and I am currently in the process of choosing which caps to order. This is where I'd like a little community wisdom.
                                  Now the capacitors inside are mostly Fuhjyyus (a forum favorite) with 1...
                                  03-25-2023, 12:18 PM
                                • slybunda
                                  AA and AAA battery charger capacitors?
                                  by slybunda
                                  hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                                  it has inside:
                                  2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                                  2 x 470uf 16v LZ105c branded as G.Luxon
                                  not heard of these brands are they any good?
                                  iv attached photos of the charger and the board inside for an idea on the type of...
                                  12-24-2023, 04:41 AM
                                  by sam_sam_sam
                                  After all of...
                                  07-13-2024, 08:14 PM
