SX280s show no physical sign of bad caps
  • robotman2009
    • Aug 2010
    Dear badcaps.net,
    Sometimes, I get some SX280s free from my wife's work when they get rid of them...I actually fixed a bad monitor given to me from my wife's work by replacing some bad caps. But anyway I have 2 Dell sx280s USFF that are showing no physical signs of badcaps. But they have the symptoms of badcaps....shutting off suddenly etc.
    From what I've been able to glean from the forums, and since I don't have anymore cash to buy some nice diagnosing equipment, it seems I am going to have to desolder the caps and test each one with my voltmeter. I have a pretty nice voltmeter that measures capacitance. So I was going to give this the old college try and see what happens. My only concern is that I read that sometimes a voltmeter can show that a capacitor is good when it actually is starting to fail...or actually may be ok when computer is off but when things heat up inside case, capacitor loses its ability to do its job.
    I am a 3rd grade teacher and want to get them running for my classroom. But there is no major rush. Any advice on progressing would be welcome.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    Re: SX280s show no physical sign of bad caps
    Recap it anyway, especially the 2200uF and the 3x 820uF by the SB and NB chips. That will usually cure that problem, I've had a few do that.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • robotman2009
      • Aug 2010
      So replace every capacitor?...but especially the ones you mentioned?
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16956
        Everything 820uF and up. Also, there's a 22uF 25v next to the CMOS battery that likes to fail.
        Team : 49813
        Join in!!
        Team Stats
          • 31036
          that 22uf will make the system slowdown & freeze - it's a real bitch!
          • robotman2009
            • Aug 2010
            Thanks guys
            • elitebooker
              2022 Asus ROG Flow Z13 I7-12700H dead troubleshooting
              by elitebooker
              Im by no means an expert, just an electronics student and my tablet-laptop died. I got it in Oct. 2024., and was having slight issues with the device, not being able to get display to show on iGPU from sleep, or sometimes it wouldnt show sign of life for no reason, a fix would be to plug the original charger into another dell,hp,macbook, then plug into my device, it would boot, or by multiple times holding the power button. The power peoblems stopped, but then started issues where it wouldnt show a display even after a fresh boot (ALL THIS WHILE MUX SWITCH IS ON IGPU)...
              06-11-2025, 11:38 AM
            • timeless
              Dell U2518 no picture
              by timeless
              I've been troubleshooting a Dell U2518 that produces no picture yet the backlight is turned on, the PSU produces 19v, It is detected over HDM and its firmware could be upgraded over USB. So to me the controller board and PSU seems (somewhat) functional.
              There is however a ticking noise from the T-Con board to the left side of the RT6811 chip when power on (not when off). Also the RT6811 chip gets quite hot (cannot be touched for long) otherwise there is no physical sign of damage and everything around the board is neatly covered with plastics and does not show any...
              04-14-2024, 08:30 AM
            • caspian
              Conversion of Anolog Voltmeter into Ammeter
              by caspian
              Dear Members,
              I have an old analog voltmeter that can correctly measure DC voltage between 0v to 3v. The voltmeter is made by Toyokeiki depicted in the photos. It does not need any battery. It works using a coil and a magnet as any other analog voltmeters.
              I am going to convert this voltmeter into a DC ammeter that can measure DC current between 0A to 15A.
              To do this, I use a 0.2 Ohm resistor for current sensing in the circuit. Then, I use the setup depicted in the photo to measure current.
              For example, if the power be 12v and the load be 8 ohms, the voltmeter shows...
              06-25-2022, 07:13 AM
            • kurland
              MacBook A1707 - low batt sign displayed then shutdown - but battery voltage is ok!?
              by kurland
              Hi fellow repair gurus,
              Liquid damaged A1707 was stuck on 5V. I replaced corroded CD3215 and SMC now successfully raises voltage to 20v.
              The fans spin, the screen comes on and displays a "low battery" sign before the machine shuts down.
              After that the screen and fan stays off but PPBUS_G3H continue to toggle every 4-5 secs between
              • 11.4v (and 170mA current draw on usb-c power meter)
              • 12.6v (zero current draw)
              The toggeling occurs when battery is connected but regardless if external usb-c is connected or not. It seems...
              10-21-2022, 02:04 PM
            • Instafixx
              IPhone 11 Temperature Sign
              by Instafixx
              Hello, Namaste.
              We have an iphone 11 for which we had changed the NAND IC and upgraded from 64gb to 128gb.
              After upgrading the iPhone shows a Temperature Sign but there is no heating in the board. We did a lot of trial and error and found that whenever the Charging Flex and Power Flex are connected together the sign shows. If either one is removed there is no such sign.
              We replaced the lower board just to check if there was a problem with the connection pads maybe but the issue persists.
              I think we have messed up while replacing the NAND. Any help from anyone...
              10-18-2022, 06:23 AM
