2022 Asus ROG Flow Z13 I7-12700H dead troubleshooting
  • elitebooker
    • Sep 2021
    • 9
    • Bosna i Hercegovina
    Im by no means an expert, just an electronics student and my tablet-laptop died. I got it in Oct. 2024., and was having slight issues with the device, not being able to get display to show on iGPU from sleep, or sometimes it wouldnt show sign of life for no reason, a fix would be to plug the original charger into another dell,hp,macbook, then plug into my device, it would boot, or by multiple times holding the power button. The power peoblems stopped, but then started issues where it wouldnt show a display even after a fresh boot (ALL THIS WHILE MUX SWITCH IS ON IGPU) if the MUX was on the RTX 3050, it works fine. i thought maybe the flex cable for lcd was cracked, checked it, and one time, after i unplugged the lcd flex *while battery was connected* it wouldnt show a sign of life. An LED is present near the USB-C charging port, never shined light after that. There is absolutely no sign of life. HOWEVER, when the motherboard was out, i noticed that when it has power, there is coil whine - WHEN I put a finger on the touchscreen, or the power button that has a fingerprint reader on it. I opened a .cad BoardView for the same model board, but with higher-spec I9 and 3050 Ti, but i dont know what to do with it, i wanted to check stuff with multimeter but dont know where to start... Can anyone help diagnose?
  • Sephir0th
    • Oct 2020
    • 1283
    I don't really like to be the one who tells you what has likely happened, but someome need to be the one who says what everyone else thinks:
    With the "bad move" of playing with the display connector while the battery was still connected you have most likely fried the Chipset. If so, the board can not (easily) recovered from this mistake anymore... but one step after another.
    We need a detailed overview of all easy accessible power supplies (coils), present voltages (while pressing the power button) and resistance to GND of each single power supply (without power). And then we will most likely know more.
    FairRepair on YouTube
    • DeXXter
      • Aug 2023
      • 102
      • Chile
      Yeah I've heard that "coil whine" noise you're talking about, usually when they got the pch (chipset) shorted/burnt. As the other user say, you probably shorted the B+ (battery voltage) onto a pch data line burning the fhck out of it while yanking the fpc connector. The only solution here is to replace the pch and since this is a 12th cpu, you will need the entire thing cpu+pch together (more expensive). As for the previous failure, that might have been an issue with the igpu power supply itself.
      • huichoger
        • Apr 2021
        • 11
        • México
        Hi can you share the files that you have please, the one with i9, that's my laptop and it wont charge or turn on, even with the mosfets behaving the Way they should, ir at least that's whats I think
          ASUS ROG FLOW-X13-GV301RE-007W Hybrid (2-in-1) Flow X13 Specification for Upgrade or Repair
          This specification for the ASUS ROG FLOW-X13-GV301RE-007W Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FLOW-X13-GV301RE-007W boardview and FLOW-X13-GV301RE-007W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
          09-07-2024, 06:40 AM
        • blues_spirit
          practical courses for troubleshooting pc motherboards
          by blues_spirit
          Hello from France,
          mon2 kindly advised me to post a thread to ask the question(s) I'm concerned about. I'm new to the forum and I'm looking for practical courses for troubleshooting pc motherboards especially laptops in Europe, if possible in France. I have been a computer network system administrator and a corrector of administration modules for automated programs under Unix. But I really miss the practical "ops" side of troubleshooting. So I would like to start from the beginning: 1.8V, 3.3V, 5V and 19V tests for example, etc...
          Do you think this is feasible for me? I...
          12-18-2022, 12:56 PM
        • KABY
          dell 3542 IGPU disable
          by KABY
          hello I'm looking for some answerer about IGPU
          i have dell 3542 with IGPU AND DEDECATE one
          the mane IGPU its not working properly every time i boot up i get some artifacts and laptop turn of and reboot again some time it boot normally for 1 min and the same scenario again artifacts and shutdown
          my question!
          is it possible to disable IGPU and run laptop with DGPU
          or there is any possibility to disable it via bios bin or take off some capacitor or coil like DGPU to disable it completely
          thanks for your accept and answer
          bios bin added and schematic...
          10-06-2023, 05:55 AM
        • corbyn
          MSI Modern 15 B7M - MS14-JK1 (14JK1) - Intermittent Crashing - iGPU?
          by corbyn
          Hey all,
          This laptop came in with hard resetting crashing, not even blue screening after a few minutes on the desktop, same result with Linux Mint.
          Strangely it seems stable plugged in on compatibility mode (nomodeset llvmpipe) which tells me I think the AMD Ryzen 7530u Radeon iGPU is cooked, but it also points to something strange with the buck converters or VRMs maybe.
          Inspecting the board under the scope there's nothing obvious.
          Crashes on charger and battery in iGPU Radeon drivers
          Crashes on battery in no driver mode
          Seemingly Stable in charger and...
          05-01-2025, 08:04 PM
        • theplop
          Razer blade 2022, 14" PI480 wont boot to OS, freezes
          by theplop
          Razer blade 2022, 14" PI480, Ryzen 6900HX, 16gb ram
          I picked up a Razer blade 14" (2022) from a friend who said it "overheated" and he replaced one of the fans. He gave up on it as windows wouldn't work/re-install. He gave it to me, and i've been working on getting linux on it. Installing Mint i was able to get about 1/4 through the installer before it froze. Now i can't even get the installer to boot. I am met with a kernel panic.... sometimes. Sometimes it just hangs on the boot sequence.
          I've run memtest quite a few times, and more often then not...
          03-20-2025, 06:42 PM
