Hello, i'm happy for you, can you share how to dump? because for dumping you must have the software no? Regards
					Drone + Game Console Boardview Files From XZZ
			This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-06-2024, 05:30 AM
			by tasoHi everyone:
 Anybody know anything about a N.switch without resistance in 6 & 19 pin (D+) in USB C conector? This is a HAC-10 board, all conector pins al good. Console runs ok but charging in very very slow 005 mAp.
 Thx!!!...
			by Natob82Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
			by grimacelordHello,
 I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
 I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
 I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
			by SluggerBI have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
 I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
 It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
- Loading...
