Dell H305P-00 case swap
  • c_hegge
    • Sep 2009
    • 5219
    I've touched on this on a few other threads, but I thought that it deserves its own thread.
    The original case was from this PSU (https://www.badcaps.net/forum/showpo...&postcount=704)
    and the innards from this PSU (http://hardwareinsights.com/wp/dell-...supply-review/)
    The new case. It had screw holes for a front 80mm fan (although I had to gut the grille out - more on that later)
    The screw holes on the Dell were a bit different to those on the case, so I snapped off the screw hole tabs, drilled some holes in the case, and installed motherboard standoffs. I made the hole on that top right one a little too big. I used one of the tabs as a nut
    Internals (with the PFC coil out of the way)
    The secondary side - Recapped, of course. I wasn't gonna let those teapos stay there. The only ones I left in place were on the -12V rail, as they aren't stressed that much, and I don't really care about that rail. It's not like it gets used much.
    The front fan connector. I originally wanted to solder it to the fan controller, but it couldn't supply enough current for both fans. With the two connected, they would only get 2.8V each and run so slow that you could still see the blades, so I left the rear fan connected to the controller, and I soldered the second connector to the 5V output.
    The Primary side
    The AC wires were too close for comfort to the cut out fan grille. I used those three large zip ties to prevent them from chafing on it.
  • DJduck
    • Dec 2012
    • 229
    • Estonia
    Re: Dell H305P-00 case swap
    Now make a cool label for it!
    I can put text here?!
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      Nice!
      • lti
        • May 2011
        • 2553
        What's the cut yellow wire for?
        • c_hegge
          • Sep 2009
          • 5219
          The cut wire led to an unusual connector which I only ever see on Dell PSUs. It wasn't needed, so I cut it off.
          • dmill89
            • Dec 2011
            • 2534
            Yes, it's Dell's proprietary expansion connector that can be used for running various extra connectors. In the Vast majority of Dells it just sits there and does nothing. There are a few exceptions, my Dell PowerEdge server has an extra string of SATA drive connectors plugged into it.
            • Pentium4
              CapXon Be Gone
              • Sep 2011
              • 3741
              Awesome, a sleeper PSU, I love it! Nice job adding the extra fan it looks good Where does the PPFC coil mount? Is that an ADDA branded Antec fan?
              • c_hegge
                • Sep 2009
                • 5219
                The PFC coil mounts to the top of the case (note the extra two screws in the first photo)
                Yes, The fans are both ADDA. I always re-lube them, though. If you give them enough lubricant, they usually last ages.
                • Pentium4
                  CapXon Be Gone
                  • Sep 2011
                  • 3741
                  Yeah, they do last a long time with enough oil and are fairly quiet. Did you hook this thing up to the load tester to see what it can do? I wonder how much better it does with the extra cooling, and I bet the efficiency increases!
                  • c_hegge
                    • Sep 2009
                    • 5219
                    I haven't loaded it since the case swap, but I overloaded it to 400W before without incident.
                    • Pentium4
                      CapXon Be Gone
                      • Sep 2011
                      • 3741
                      That's pretty impressive. So it just shut down over that?
                      • c_hegge
                        • Sep 2009
                        • 5219
                        Nope. I don't think it has OPP. It let me power it on under 600W load, but I only let it run for a few seconds. I didn't want to kill it, as it is a pretty decent PSU. It's the gutless wonders that I enjoy seeing go out with a fireworks display.
                        • Pentium4
                          CapXon Be Gone
                          • Sep 2011
                          • 3741
                          Well I'm glad you didn't kill it. It's a nice PSU indeed. That's pretty impressive though even for a few seconds, considering it only has one switcher
                          • Bowline
                            by Bowline
                            06-11-2025, 10:13 AM
                          • kleung
                            Dell ultra 7070 ,Foxconn PWM laptop case fan. Spins at 100% speed in failure mode.
                            by kleung
                            I wanted to add to the knowledge base about a PWM case fan that it can fail at 100% speed.
                            On my Dell ultra 7070 (this is a 0.6 L pc so uses laptop parts); I had the case fan suddenly go 100% and I couldn't control it. I disconnected/reset bios and it was only solved when I swapped in a replacement fan.
                            I have tested and there is continuity between the 4 wires pins and the circuit board.
                            That is the extent of my troubleshooting. I took pictures of the circuit board but don't know what component would die (PWM controller?) that could cause this to happen....
                            12-07-2024, 01:45 AM
                          • master3112
                            Dell Inspiron 5590 Board 18778-1 no charging, charging not possible
                            by master3112
                            I would like to share my experience about charging issues with Dell power supplies with the tech community. I am working on a Dell Inspiron 5590, Mainboard 18778-1 with charging problems. The device can be switched on and works so far, only the message appears at startup:
                            Alert! The AC power adapter wattage and Type cannot be determined. The battery may not change. The System will adjust the performace to match the power available.
                            The power supply unit is not recognized in the Bios and the charging process is set to "idle". I use original Dell battery, type...
                            07-29-2025, 01:55 PM
                            ASUS E410MA-BV190TS-CASE Notebook Specification for Upgrade or Repair
                            This specification for the ASUS E410MA-BV190TS-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E410MA-BV190TS-CASE boardview and E410MA-BV190TS-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                            09-06-2024, 10:50 PM
                            ASUS 571GT-AL188R-CASE Notebook Specification for Upgrade or Repair
                            This specification for the ASUS 571GT-AL188R-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 571GT-AL188R-CASE boardview and 571GT-AL188R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                            09-06-2024, 11:05 AM
