I don't know if anyone of you is familiar with that name. I got that power supply from a friend, he told me his computer stopped working.
By the time I opened the case it looked familiar. Either Macron Power is the OEM or they copied them. Just compare the add on board of MPT-350 and Trust, the layout of the PCB, the spot of the fan connector, the 5vsb output caps and choke, etc.
Even the psu case is the same, apart from the black paint.
"XHY-300AB", the PCB code is located at the same place where the MPT-301 and MPT-350 have "ATX991 2P Macron Power".
But is it a decent power supply?
-The input filter is ok but there are no MOVs.
-3A diodes instead of a bridge rectifier. I could forgive that.
-2x470uF 200V CS caps. Real capacitance is 352uF and 323uF. I call those 330uF caps.
-2x 13007 switching transistors. This is more like a 250W (300W peak) unit, not 370W.
-Good ERL35 transformer
-3.3V: S20C45C (20A), 2x2200uF 10V BH caps. Good to see 2200uF caps on a psu like this.
-5V: S20C45C (20A), 2x2200uF 10V BH. The 30A the label claims is just a lie.
-12V: U20C20 (20A) 1x2200uF 16V BH
All the caps are BH, except a Sapcon 100uF 50V and the CS primaries. 2 10uF 50V BH caps are bad with esr up to 20ohm when the maximum allowed is 3.5ohm. There is severe heat discoloration on that area. Maybe that's the reason it stopped working.
There is something really nasty on the back side of the PCB, something like glue that is very difficult to clean...
One of the two 13007 gives me a short between Base and Collector. Is this normal or it needs to be replaced?
