Hp-530
  • valcon
    • Apr 2012
    • 2
    • jordan
    Hp-530
    Dear all,
    i have HP-530 motherboard, shorted power circuit & repaird previously and i need the mosfet no's for PQ3, PQ4, PQ36 & PQ39 or any equivalent for it.
    when i pluged to charge the charger go off
    thanks
  • Nocta
    • Mar 2012
    • 117
    • Argentina
    Re: Hp-530
    What's the number of the mosfet? Have you tried looking for equivalents on alldatasheet?
    • b700029
      Banned
      • Sep 2010
      • 640
      Re: Hp-530
      These are in the vcore controller circuit:
      PQ36 SI4684DY-T1-E3_SO8
      PQ39 SI4684DY-T1-E3_SO8
      https://cdn.badcaps-static.com/pdfs/...5f0dc702c5.pdf
      These are for main power switching:
      PQ3 FDS4435BZ_SO8
      PQ4 FDS4435BZ_SO8
      From schematic:
      • valcon
        • Apr 2012
        • 2
        • jordan
        Re: Hp-530
        Thank you b700029, the motherboard was repaired in the past by other, when i checked it i noticed that the PQ36 & PQ39 replaced with 4474 and 4433 mosfet, the PQ3 & PQ4 soldered and the no's for it not cleared.
        Thank you again.
        • cpp
          • 9
          Re: Hp-530
          I have the same board for repair,PQ 38,37,40 and 41 shorted,
          there are FDS6676AS,
          in my board PQ 36 and 39 are AD4684 (not sure for the brand)
          and PQ 3 ,4 are AO4433
          • luktech
            • Apr 2013
            • 12
            • Nigeria
            Re: Hp-530
            hi. Mine is a no power fault. I measured the value of the pin 1-4 of q4 to be 18.5v but the output pin 5- 8 is 0.3v. Could it be the cause. If yes can i use the Q4 of other board.
            • spidey
              climbs
              • Dec 2012
              • 648
              • Cyprus
              Re: Hp-530
              Did you checked the date of last message ?
              it is better to make a new thread with more information, your board model, measurements, maybe some photos.
              • luktech
                • Apr 2013
                • 12
                • Nigeria
                Re: Hp-530
                I cant find where to post new thread. Pls how will I.
                • spidey
                  climbs
                  • Dec 2012
                  • 648
                  • Cyprus
                  Re: Hp-530
                  https://www.badcaps.net/forum/forumdisplay.php?f=23
                  check upper-left corner there is a new thread button..
                  • luktech
                    • Apr 2013
                    • 12
                    • Nigeria
                    Re: Hp-530
                    thanks.
                    • wnt2fx
                      BQ24738h - not charging - HP Model G7BJ - dag7bjmb8c0 Rev. C
                      by wnt2fx
                      Hello dear tech freaks :-)
                      can i have your thought on this one ? I have no clue. In lack of schematics I used HP 15-p DAY11AMB6E0 for orientation in the BQ24738H area. I have no experience with this power IC.
                      The machine had a full short on +vin, caused by a dropped screw in the owners attempt to replace the battery. After removing the biggest among 4 small caps on that line, right at the input of PQ36 the machine was working again.
                      Everything seemed to work and after a while of testing I noticed that pq36/pq37 were reaching about 130C. One...
                      01-27-2023, 11:26 AM
                    • delphi_firebird
                      Macbook Air A1466 does not turn on when pluged
                      by delphi_firebird
                      Hello
                      I have a Macbook Air (820-3437) that have an startup issues :
                      - it starts right away when i plug the charger ( even with a good connected battery) .
                      - when shut down, if i press the power button it wont startup when the charger is plugged in but starts when i unplug the charger ( on battery ).
                      - i have no issue with charging battery .
                      - i had already checked SMC_ONOFF_L , PM_PWRBTN_L are OK
                      Can you please help me to figure out the problem ?
                      Thank you
                      03-29-2022, 09:43 AM
                    • caspian
                      ECS MCP61M-M3 Chipset gets hot when Graphics card is pluged
                      by caspian
                      Dear Forum Members,
                      I have an ATX mainboard: ECS MCP61M-M3 with CPU: Sempron 140 and Chipset: MCP61.
                      If I use only the Onboard Graphics, the Chipset's temperature is about 52'C.
                      If I use a PCIE x16 Graphics Card, the Chipset's temperature is about 70'C and tends to go higher. But the Graphics Card's temperature is normal.
                      In both the two cases, the PC works fine.
                      I have tested two different Graphics cards and it gets hotter with both of them.
                      Any idea why it gets hotter with Graphics Card?
                      03-03-2022, 04:56 AM
                    • Frenk7
                      MacBook Pro working only with HDMI pluged in!!??
                      by Frenk7
                      I have MacBook Pro A1502 that was in contact with liquid on the keyboard side. I found that keyboard backlight connector is burned so i pluged it out and cleaned connector on motherboard side. Present state is next: when i turn on laptop after 1-5 minutes screen freezes, but the strange part is that if i plug in second monitor on HDMI port, both monitor and laptop screen work and nothing is freezing. Can you please help me?
                      I am thinking that there are two circuit or two ic. When i plug in second screen second line (that was not affected by burned keyboard backlight) takes over and all...
                      03-27-2019, 08:20 AM
                    • kodox
                      ThinkBook 15 G3 ACL Not Charging Battery - LA-K602P Board
                      by kodox
                      since i couldn't find schematic or boardview for this model (LA-K062P), i use closest board model found here https://www.badcaps.net/forum/troubl...-and-boardview
                      the schematic share same marking for each component, using same PD-Controller, same BQ25710, the only different is the battery cell used. LA-K061P uses 3S battery while LA-K062P use 4S battery per schematic.
                      what i've done:
                      - flashing...
                      12-29-2024, 02:49 AM
