Antec SL300S Standby Voltage high.
  • jdTech
    • Jul 2011
    • 6
    1st, I know... just dump it
    I have a Antec Smart Power SL300S that the standby voltage is reading ~6.35 unloaded. If I load it the voltage drops to ~5.0V:
    10 ohm load output is 5.08V
    5 ohm load output is 5.07V
    2.5 ohm load output is 5.05V
    This unit had bad Fuhjyyu caps on the +3.3, +5.0, and +12.0V rails. It was working in my dad PC until the fan stopped work. When I when to change the fan I noticed the bad caps. It sat in the to do pile until now. After changing the caps and testing I noticed this STANDBY voltage issue.
    When I jump the TURN-ON to GND and main supply comes up the the STANDBY drops to ~5.0V.
    I don't think this is normal since the label states 0 amps for a min STANDBY load. Also, there is a internal 50 ohm load on the STANDBY rail.
    Changing the two 680uF STANDBY filter caps didn't help.
    Thanks!
    Jim
  • c_hegge
    • Sep 2009
    • 5219
    Re: Antec SL300S Standby Voltage high.
    There should be a small 22uF 50V in the 5vsb circuit. replace it. It often causes the 5vsb to go too high when it fails. It it's still no good, then it's time for a DM311 mod or a new PSU.
    • Toasty
      • Jul 2007
      • 4171
      See: https://www.badcaps.net/forum/showthread.php?t=8024
      If it's anything like the 350 or 400, replace all the little caps. The mains caps aren't really a problem.
      veritas odium parit
      • Longbow
        • Jun 2011
        • 623
        That's good know from experience, but I don't see how it relates to the information given by jd. His loaded voltages look just fine. Some supplies cannot be evaluated under a no-load condition. That is why, for example, that you see load clips available from PC Power and other manufacturers. Great photos and tutorial from Toasty on this supply!
        Is it plugged in?
        • Toasty
          • Jul 2007
          • 4171
          The 5vsb should remain in spec whether it is loaded or unloaded. If it's floating high with no load, then something is wrong. c_hegge is correct in that cap replacement, but I do all the little ones too -
          1) because I'm there (and don't want to go back, ever!)
          2) it's cheap insurance
          veritas odium parit
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            ""it's cheap insurance""
            Like tin foil.
            Mann-Made Global Warming.
            - Dr Seuss
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              • Romania
              You should also put a 5.1v 1W zener on that rail after you fix it. If it decides to go wonky, the zener will eat up the extra power. If it decides to go REAL wonky, the zener will short and blow up the switching transistor, but at least the motherboard will survive.
              A working TV? How boring!
              • jdTech
                • Jul 2011
                • 6
                Thanks for all the input! Here is an update.
                Changing C14 (22uF 50V) lower the STANDBY to ~5.7V. Changing C8 (47uF 25V) did the trick, STANDBY now reads 5.10V.
                I'll now change the remaining small caps.
                BTW, I did find the the main supply would not turn on until the STANDBY voltage was =< ~5.5V. Also, the STANDBY would start out at ~6.3V and then slowly fall.
                I was thinking about the zener across the output myself. Is there a low voltage MOV that would work better or faster?
                Thanks again for everyone's help!
                Jim
                • jdTech
                  • Jul 2011
                  • 6
                  BTW, that 47uF (C8) read about 5nF on my cap tester!
                  Jim
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    • Romania
                    No, just use a normal 1 watt zener. Best protection there is.
                    • everell
                      • Jan 2009
                      • 1514
                      Here is a picture of a Fortron power supply that had the zener diode and failed. The heat sinks and 5vsb transformer have been removed so that you can see how extensive the burn damage is to the pc board. The motherboard may have been saved but the power supply is not very fixable because the burn damage goes all the way thru the pc board. This board went to the junk pile!
                      Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
                      • AJ847.63e
                        Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
                        by AJ847.63e
                        Hi Folks,
                        Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
                        I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
                        The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
                        05-06-2025, 10:37 PM
                      • CWEastwood
                        Antec Smart Power SL300S capacitor replacement.
                        by CWEastwood
                        I'm currentlly in the process of trying my first power supply repair (really my first soldering project) and have some questions with regard to which capacitors to replace the bad ones.
                        The power supply is an Antec Smart Power SL300S ATX12V 300 watt.
                        I have successfully desoldered every capacitor from the board without destroying anything (I think) and I am currently in the process of choosing which caps to order. This is where I'd like a little community wisdom.
                        Now the capacitors inside are mostly Fuhjyyus (a forum favorite) with 1...
                        03-25-2023, 12:18 PM
                        NE1101A-S0, NE1101B-S0, NE1101A-S0T, NE1101B-S0T, NE1101A-D0T, NE1101B-D0T Datasheet
                        The NE1101A-S0, NE1101B-S0, NE1101A-S0T, NE1101B-S0T, NE1101A-D0T, NE1101B-D0T are a current mode controller which contains advanced features to meet the stringent worldwide green energy requirements.
                        Among the advanced energy saving functionalities include the NE1101A/B include a low leakage high voltage startup current source that minimize no load standby power losses It has a PFC VCC pin which is capable of delivering 35mA to the front stage PFC controller.
                        This bias will cut off automatically when the IC enters Green mode under light load. This feature simplifies...
                        10-07-2024, 05:18 AM
                        HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                        This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                        09-12-2024, 02:20 PM
                        HP EliteBook 1050 G1 + Image Load, Asset Tag & Testntag Notebook 1000 Specification for Upgrade or Repair
                        This specification for the HP EliteBook 1050 G1 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load, Asset Tag & Testntag boardview and 1050 G1 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                        09-06-2024, 10:56 AM
