NE1101A-S0, NE1101B-S0, NE1101A-S0T, NE1101B-S0T, NE1101A-D0T, NE1101B-D0T Datasheet
    The NE1101A-S0, NE1101B-S0, NE1101A-S0T, NE1101B-S0T, NE1101A-D0T, NE1101B-D0T are a current mode controller which contains advanced features to meet the stringent worldwide green energy requirements.
    Among the advanced energy saving functionalities include the NE1101A/B include a low leakage high voltage startup current source that minimize no load standby power losses It has a PFC VCC pin which is capable of delivering 35mA to the front stage PFC controller.
    This bias will cut off automatically when the IC enters Green mode under light load. This feature simplifies the PFC circuit design and reduces power losses Under light load, the NE1101A/B enters burst mode to maintain high efficiency operation The NE1101 also features frequency dithering function that spreads the EMI spectrum and saves the cost on EMI solution.
    Other features that incorporated in the NE1101 are latched OVP, OCP, OTP functions, which is triggered by pulling CS pin above 3.0V and reset by pulling it to ground.
    The switching frequency of NE1101A is internally fixed at 100KHz. The NE1101B is fixed at 65KHz.
    These two versions are available in SO8 and DIP8 packages
    Features
    ● Current mode control with Internal slope compensation
    ● High-Voltage Startup current source
    ● Peak current limited Burst mode
    ● Internal 2.5mS soft start
    ● Internal 200nS Leading Edge Blanking
    ● Cycle-by-Cycle current limit
    ● Latched OCP & OVP functions
    ● Frequency Jittering for EMI reduction
    ● Over Temperature, over load protections
    ● Automatic PFC bias supply output
    Applications
    ● General 30W-100W flyback SMPS
    ● AC adaptor for Notebooks, Printers
    ● Off-line battery chargers
    ● LCD monitors, Set-Top boxes, power tools
    ● Open-frame SMPS
    ● Standby power for TVs, PCs, Home appliances​
    Texas Instruments bq24745 bq24745RHDR bq24745RHDT Battery Charger IC for Laptop Computers Datasheet
    The bq24745 bq24745RHDR bq24745RHDT is a high-efficiency, synchronous battery charger with an integrated input-current comparator, offering low component count for space-constrained, multi-chemistry battery-charging applications. The input-current, charge-current, and charge-voltage DACs allow very high regulation accuracies that can be easily programmed by the system power-management microcontroller using the SMBus interface. The bq24745 charges two, three, or four series Li+ cells, and is available in a 28-pin, 5-mm x 5 mm QFN package.
    The bq24745 features dynamic power management...
    10-23-2024, 02:50 AM
    Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
    I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
    I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
    I tested the battery cells there are installed right now and they are testing good with no issues that I...
    02-04-2025, 08:08 PM
  • quickname
    Cyberpower 1500AVR UPS repair
    by quickname
    I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
    I decided to verify that the batteries were...
    11-12-2023, 09:57 AM
  • AJ847.63e
    Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
    by AJ847.63e
    Hi Folks,
    Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
    I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
    The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
    05-06-2025, 10:37 PM
    NVDC charger configuration...
    11-05-2024, 03:28 PM
