Acer v193w
  • newton
    • May 2010
    • 5
    Acer v193w
    Good day to all forum,
    I would need the service manual of this monitor ACER V193W.
    The problem with this monitor is as follows:
    lights for a few seconds, you see the logo and just after the lights go out.
    Can someone tell me how do I remove the back cover (I do not think there are screws).
    Thanks!
  • gerg
    • Nov 2010
    • 278
    Re: Acer v193w
    Check this guide out it's really nice and has helped me out a time or two
    • PlainBill
      • Feb 2009
      • 7034
      Re: Acer v193w
      Service manual.
      PlainBill
      • newton
        • May 2010
        • 5
        Re: Acer v193w
        Ok thanks!
        Now I make the checks and then tell you how it went.
        • lkvee
          • Feb 2009
          • 198
          My Acer v193w has a different problem
          Just got one myself. It displayed typical behavior in terms of power. I got the "Cable Not Connected" message and the "No Signal" messages when I turned it on and plugged in the video cable. I was not able to get a video image, so I focused on the video board.
          All are Su'scon caps. Three of them at 10 uF and 25V tested around 9 uF and 4.1 - 4.5 Ohms on my ESR Micro 3.1 and all capacitors were tested in-circuit.
          The capacitor opposite the VGA port and the one near the center feature 150 uF and 10V and tested around 93 uF and 0.30 - 0.45 Ohms.
          I'm worried about the one on the opposite corner from the VGA port. It features 100 uF and either 10 or 16 Volts. When I apply my ESR Micro 3.1 needle probes, the meter freezes (it was set to cycle between displaying capacitance and displaying ESR). I have to remove at least one probe to get my meter to cycle again. While I get ESR around 0 Ohms, capacitance is anywhere from 1000 Ohms to (X times 10^4) Ohms.
          I'm planning to start with this wacky capacitor, but I'm also wondering if I should work on the other five.
          I can't figure out the best way to remove the power board, either.
          • newton
            • May 2010
            • 5
            Re: Acer v193w
            after a long time I resumed work this monitor.
            The problema is solved by changing one of the four lamps that I found dead.
            Thanks to everyone for the help.
            • vijensharma
              • May 2013
              • 2
              • israel
              Re: Acer v193w
              I have exactly the same situation, can you elaborate which four lamps you replace. Thanks in advance.
              • vijensharma
                • May 2013
                • 2
                • israel
                Re: Acer v193w
                  Re: Acer v193w
                  One of the four CCFL lamps, there are 2 for the top, 2 for the bottom.
                  It can be burnt out wires, worn out lamp (blackened ends).
                  http://s807.photobucket.com/user/bud...?sort=3&page=1
                  You can make 2 test lamps to find out if you have inverter problem or bad lamp.
                  https://www.badcaps.net/forum/showthread.php?t=19987
                    by momaka
                    03-15-2023, 10:17 PM
                  • maralexbar
                    How to force Acer Aspire Series to bootup BIOS/UEFI on external Monitor?
                    by maralexbar
                    I ask this question in general as there are many Acer Aspire models with UEFI Insyde BIOS that do not boot to the BIOS on an external monitor (VGA, HDMI, etc) showing only the Internal LCD (LVDS, eDP etc).
                    It's a pain to work on Acer notebooks with a broken screen and not being able to access the BIOS using an external monitor.
                    If anyone knows how to force the external monitor as primary for Notebooks of those models
                    11-02-2024, 09:18 AM
                  • keepread
                    Dell monitor PSU vs Dell laptop PSU
                    by keepread
                    Hi there!
                    Someone gave me their old monitor, it's Dell S2715ht.
                    The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
                    Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
                    10-30-2025, 04:45 PM
                    09-06-2024, 05:27 AM
                    Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                    This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                    09-07-2024, 05:00 AM
