#1 |
City & State: Halifax, NS
My Country: Canada
Line Voltage: 120VAC 60Hz
I'm a: Complete Noob!
Hi again,
I've recently made a purchase of a new Golden Field ATX-S628 550W peak power PSU that was being sold at a local computer shop I know for $38 CAD. It actually had some weight to it, along with a few other things that made it attractive to me at that price. I'll have it on hand as a backup PSU, in case my Antec PSU fails. It appears to be a great PSU for the money I spent on it, as it has beefier heatsinks than normal cheap power supplies, has a 120mm fan, nice dark gray finish, and comes with a decent secondary side and a transient filtering stage (two Y caps, two X caps, and a coil). The caps in this PSU are BH brand, which I haven't heard anything bad yet about them (but they do look like cheap Taiwanese caps, IMO). ![]() The complete package. ![]() ![]() ![]() Three shots of this PSU. ![]() This PSU has one 24-pin ATX connector, two P4 12V connectors (that can be joined together for EPS12V), one PCI-E 6-pin connector, three 4-pin peripheral (molex) connectors, and two SATA power connectors. This arrangement I believe will suit most basic computers. ![]() A shot of the label. Note the "Oiliness Bearing Fan" remark. ![]() Overhead shot of this PSU's internals. Notice that it is not completely gutless. ![]() A shot showing the transient filtering stage, and the two primary caps. ![]() The primary caps are two BH 680uf 200V. ![]() The best picture I could get of the KBL406 4A 800V bridge rectifier. It being 4A, the most this power supply could draw from a 120V AC outlet would be 480W. ![]() A shot of the primary side silicon. One CET CEF02N6A 600V 1.4A n-channel transistor, along with two 13009 NPN power transistors. ![]() ![]() ![]() Three shots of the secondary side. ![]() A shot of the secondary side silicon. The one on the left is an S20C45C 20A 45V Schottky rectifier, the one in the middle is an S30D40C 30A 40V Schottky rectifier, and the one on the right is a U20C20C 20A 200V power rectifier. I doubt that this PSU has two 12V rails, as on the label, since there is only one power rectifier for the 12V. Correct me if I'm wrong. ![]() The 120mm fan used in this PSU is a Yate Loon D12SL-12 12V sleeve bearing fan, which operates at 1350RPM, pushing out 47CFM of air at a noise level of 28dB. ![]() The fan connects to this additional board in the PSU. I'm not sure what it exactly does, but I'm guessing it's some sort of fan controller, as the package indicates an "Adjustable Fan Speed Controller". If you know what it is, tell me. It has an LM339N on it. ![]() This PSU uses an SG6105 PWM controller chip. I haven't even powered on this PSU yet. The rating on the label is 550W, but that's the peak power rating. I would guess that this PSU's continuous rating would be at 400W, considering how the PSU looks inside, and the rating of the bridge rectifier. If you would like to view the webpage on the Golden Field website on this power supply, click on this link: http://www.goldenfield.com.cn/en/ProductView.asp?ID=146 Anyway, feel free to comment about your opinions on this Golden Field ATX-S628 power supply.
My gaming PC: AMD Phenom II X6 1090T Black Edition 3.2GHz six-core processor (Socket AM3) 16GB G.SKILL Value Series DDR3-1333 RAM (4x4GB dual channel) ASUS M4A77TD motherboard PowerColor AMD Radeon HD 7870 2GB GDDR5 PCI-Express x16 3.0 video card (AX7870 2GBD5-2DHV2) Samsung EcoGreen F2 HD154UI 1.5TB SATA-II Hard Drive ASUS Xonar DG 5.1 Channel PCI sound card Antec HCG-400 400W ATX12V v2.3 80 PLUS BRONZE Power Supply Microsoft Windows 7 Ultimate SP1 64-bit Antec Three Hundred mid-tower case
#2 |
Large Marge
Goldenfield uses two OEM's, one is Huntkey and the other is Sunpro.
This looks like a huntkey. |
#3 |
My Country: Australia
Line Voltage: 240V 50Hz
Re-cap it. It's probably not too bad after that.
I love putting bad caps and flat batteries in fire and watching them explode!! No wonder it doesn't work! You installed the coils backwards ![]() Main PC: Core i7 3770K 3.5GHz, Gigabyte GA-Z77M-D3H-MVP, 8GB Kingston HyperX DDR3 1600, 240GB Intel 335 Series SSD, 750GB WD HDD, Sony Optiarc DVD RW, Palit nVidia GTX660 Ti, CoolerMaster N200 Case, Delta DPS-600MB 600W PSU, Hauppauge TV Tuner, Windows 7 Home Premium Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 4x 250GB HDD (2 in RAID 1), 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 Pro |
#4 |
Large Marge
It's probably good for 300w. 13009's are good for about 300w continuous, 350w peak if cooled well. Only 1 20A ultrafast on the 12v, and yes, it's only single rail as it doesn't even have OCP.
#5 |
Grumpy Old Fart
City & State: Phoenix, AZ
Line Voltage: 120V 60Hz
UL mark has no number => Fake.
Mann-Made Global Warming. - We should be more concerned about the Intellectual Climate. - Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind. - Dr Seuss - You can teach a man to fish and feed him for life, but if he can't handle sushi you must also teach him to cook. - |
#6 | |
City & State: VA
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I'm a: Student Tech
As far as fan controller - look for a thermal resistors near the secondary side of the PSU - it's usually marked on the PCB as NTC, PTC, TR, or THR. If you see one, there is a thermal fan controller. Aside from the BH caps, it doesn't look at all that bad. For $38 CAD, though, I would have expected to see Teapo or at least Ost in there. Even LTec would be preferable to BH. |
#7 | |
o.O
City & State: Duisburg
My Country: Germany
Line Voltage: 230VAC 50Hz
interesting enough, only a few of them were actually Fuhjyyu.. most of the caps in there were Crapxon (KM and GL). refused to turn on one day.. so i junked it.. was too crammed (lots of daughterboards + jumperwires across the whole PSU) and shoddily built (thin wiring, underrated components (if not missing)) to be worth fixing.. label wise it was a 420W IIRC. inside looked more like 350W.. at best.. with lots of tailwinds from the dual 80mm fans.. edit: by the way.. "BH" is a common abbreviation for bra in german lol (büstenhalter -> BH .. could be roughly one-to-one translated as breastholder) http://www.dict.cc/?l=e&s=BH ![]()
The USA have Barack Obama, Bob Hope, Stevie Wonder and Jonny Cash. We have Angela Merkel, no hope, no wonder, no cash.
#8 |
Large Marge
Interesting, on System General's website they have a schematic for a power supply that is 300W that utilizes the SG6105.
It does have OPP though. |
#9 |
City & State: Valkeakoski, Pirkanmaa
My Country: Finland
I think i can just see a second TO-220 pack rectifier for the 12v, on the other side of the heatsink in the overhead shot. Quite a common arrangement, from what i've seen.
#10 | |
My Country: Canada
![]() ![]() So Golden Field actually wasn't lying about this PSU having two 12V rails. I do not plan to recap this PSU, as I don't have the time and money to do so right now. The BH caps should be okay, since if I ever need to use this PSU, it'll only be for backup purposes only and wouldn't be used for a long time. |
#11 | |
Large Marge
The two diode packs run in parallel to double the capacity. This does not mean it has 2 rails. Usually multiple rail units only have 1 or 2 12v outputs on the transformer and multiple rectifiers running in parallel. This is then split into multiple outputs after the chokes with shunts to monitor the amount of amps running through each rail. |
#12 | |
My Country: Canada
#13 | |
Grumpy Old Fart
Heat dissipation -to- amps is logarithmic in silicon. 1 @ 10 amps gives off much more heat than the total heat dissipated by 2 at 5 amps each. Means less heat-sink area is required and a smaller fan can be used. . |
#14 |
Large Marge
In this case it was probably a heat vs capacity issue. They needed to make as least heat as possible while still at least meeting the specs on the label.
Though, I don't know. Ultrafasts generate more heat than schottky's, they could have just gone with 1 to-247 40A schottky and it probably wouldn't have gotten any hotter than 2 20A ultrafasts in parallel. Might be a cost issue there, I don't know how much more a single 40A to-247 schottky costs versus 2 20A to-220 ultrafasts. |
#15 | |
Black Sheep
BH is a very lame brand, i would never trust 'em... do yourself a favor and recap it when you have the funds...
(Insert signature here) |
#16 | |
My Country: Canada
#17 | ||
City & State: VA
My Country: U.S.A.
I'm a: Student Tech
Deer PSUs, for example, are known to put a 2W, 100 Ohm resistor on the 12v rail. That's (12^2)/100 = 1.44 watts of heat from that resistor. Doesn't seem like a lot, but it is - usually enough to darken the PCB and the sleeve on many caps. |
#18 | |
My Country: Finland
Yeah, schottkys DO have lower forward voltage drops than ultrafasts (and thus less heat dissipated for a certain current going through them), but i think i read somewhere that there are / might be peaks higher than 40v on the 12v line, rendering the use of (even 40v) schottkys somewhat risky. And regarding the price, a quick browse through OnSemi's site shows that a to-247 60A 45v "L-series" schottky is 1,46$ (2$ for a "normal" 30A 45v), while a to-220 16A 200V ultrafast is 0,44$ (unit price for 1000pc, i believe). |
#19 | ||
My Country: Canada
Also, the Yate Loon 120mm fan should also provide ample ventilation for this power supply. Quote:
#20 | |
My Country: Finland
In fact, that could make one wonder why they "spoil" us with schottky's at all ![]() |
