I've been given this Shuttle X a few months back. Before i even got to take a look at it, i ended up borrowing it to someone who didn't use it at all, finally got it back a couple days ago. It didn't work. Turns out the Clear CMOS jumper was missing - this machine doesn't even spin the CPU fan if that's missing, very interesting.
Tried to put my laptop HDDs in, turns out i was SOL with the onboard VIA SATA controller, unless my HDDs have jumpers for SATA 1 mode, which they don't. I had this Silicon Image card lying around, but i had a problem with it. For some reason i cannot comprehend, one of the SATA ports was on the back of the card, on the PCI bracket, instead of inside the computer. Nothing my soldering iron, braid and flux couldn't fix.
Btw, the notation on the PCB is reversed. The hacked port, labeled SATA 2, is actually SATA port 0, and is where the boot HDD (the 160GB WD) is connected.
Then, of course, more trouble. I needed to flash a "base" (non-RAID) BIOS on the Sil3112A before Win7 would let me install - it would deny me installation because "your computer may not be able to boot from this drive". Really? Fortunately, flashing a non-RAID BIOS on the card allowed me to proceed.
I would have installed XP, but it crashed with a 7B BSOD after text mode setup. I think the driver for the Sil3112A on that CD is wrong, because it kept calling it "ASH1205" and i'm quite sure it said Sil3112A when i had this card in my dual-PIII and it worked.
Unfortunately i don't have the funky CPU heatsink w/heatpipes the Shuttle came stock with, if anyone has one lying around, maybe we can make a deal. The SATA power connectors are another hack as it didn't have those, but i didn't post pics of that as there's nothing particularly interesting about soldering some wires to a PSU PCB.
