Silicon Image 3112A SATALink port hack
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    I've been given this Shuttle X a few months back. Before i even got to take a look at it, i ended up borrowing it to someone who didn't use it at all, finally got it back a couple days ago. It didn't work. Turns out the Clear CMOS jumper was missing - this machine doesn't even spin the CPU fan if that's missing, very interesting.
    Tried to put my laptop HDDs in, turns out i was SOL with the onboard VIA SATA controller, unless my HDDs have jumpers for SATA 1 mode, which they don't. I had this Silicon Image card lying around, but i had a problem with it. For some reason i cannot comprehend, one of the SATA ports was on the back of the card, on the PCI bracket, instead of inside the computer. Nothing my soldering iron, braid and flux couldn't fix.
    Btw, the notation on the PCB is reversed. The hacked port, labeled SATA 2, is actually SATA port 0, and is where the boot HDD (the 160GB WD) is connected.
    Then, of course, more trouble. I needed to flash a "base" (non-RAID) BIOS on the Sil3112A before Win7 would let me install - it would deny me installation because "your computer may not be able to boot from this drive". Really? Fortunately, flashing a non-RAID BIOS on the card allowed me to proceed.
    I would have installed XP, but it crashed with a 7B BSOD after text mode setup. I think the driver for the Sil3112A on that CD is wrong, because it kept calling it "ASH1205" and i'm quite sure it said Sil3112A when i had this card in my dual-PIII and it worked.
    Unfortunately i don't have the funky CPU heatsink w/heatpipes the Shuttle came stock with, if anyone has one lying around, maybe we can make a deal. The SATA power connectors are another hack as it didn't have those, but i didn't post pics of that as there's nothing particularly interesting about soldering some wires to a PSU PCB.
    A working TV? How boring!
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Silicon Image 3112A SATALink port hack
    Ugh, looks like the mobo has yucky caps on it. Better replace those! :O
    Muh-soggy-knee
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      • Romania
      It's full of OSTs but all are good. PSU has Panasonic primary and all Teapos in secondary, again, everything's fine. Apart from a low 12v rail, it works perfectly. This board isn't worth investing any money in, and it does fine as it is, so i'm leaving it at that.
      I was even able to overclock the 1.5GHz Sempron 2200+ to 1.71GHz (190FSB), and that with reduced voltage, 1.425v as opposed to 1.6v stock! It now runs faster AND cooler than stock. I was also able to tweak the RAM timings quite a bit. The FSB won't go any higher without BSODing because this board does not have PCI/AGP locks.
      I should be getting an Athlon 2600+ to play with in the next few days, looks like this little machine will actually be useful.
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        You should have bought the super duper high end version with jumper switches for selecting eSATA or SATA mode
        On mine they recouped the losses in the jumper switches by using a ROM instead of a EEPROM so the BIOS can't be upgraded, fantastic!
        Btw, could you not just have loaded the RAID drivers for it in Windows setup instead of installing the base BIOS on it?
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          I had to load drivers in both cases. The problem was that in RAID mode Windows 7 threw an error message saying it could not be installed on this disk, because the system may not support booting from this disk, and didn't allow me to go further. Something like this:
          • lti
            • May 2011
            • 2557
            They put the RAID BIOS on it when it only has one internal SATA port, and the external port is a standard SATA port instead of eSATA?
            • Per Hansson
              • Jul 2005
              • 5895
              • Sweden
              lti: Haha, yea, it did not even occur to me until you said it now, Amazing!
              • Gabriel
                • Jan 2010
                • 620
                • Norway
                I have a cardbus Sil3112 in my drawer, had to see if I was able to flash the card. Tried every driver on Silicon Image homepage but the browse and program flash was greyd out.
                Also tried the windows flash tool, could not get it to work.
                Got courious, maybe I will open the pcmcia card and see what chip it has and do a manually flash.
                • larrymoencurly
                  • Oct 2004
                  • 960
                  I've never been able to get the Windows flasher for Silicon Image to work, but the DOS flasher always worked for me (had to boot to DOS). There's also a utility that supports those cards plus several others, at http://www.FlashROM.org.
                  • Gabriel
                    • Jan 2010
                    • 620
                    • Norway
                    Opened the pcmcia card, sadly no separate eprom on this board so no chance of updating the firmware.
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      • Romania
                      In the meantime, i've unlocked my Sempy via the L5 bridge method, and have bumped it up to 2GHz at x11 multiplier (was locked at x9 previously). I'm kinda pushing the FSB limit of the motherboard tho, so i might take it out again and cut some of the L6 bridges to get even higher multipliers.
                      I have an Athlon XP 2600+ coming in the mail, but i think i'm still going to play with the Sempron a bit more, just for fun.
                        HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                        This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                        09-12-2024, 02:20 PM
                      • Jaime Morillo
                        Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                        by Jaime Morillo
                        Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                        The TV was stuck on the logo and I couldn't access the update menu.
                        I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                        The image result was good, but the image is inverted.
                        The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                        Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                        08-18-2025, 11:38 AM
                        HP EliteBook 1050 G1 + Image Load, Asset Tag & Testntag Notebook 1000 Specification for Upgrade or Repair
                        This specification for the HP EliteBook 1050 G1 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load, Asset Tag & Testntag boardview and 1050 G1 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                        09-06-2024, 10:56 AM
                        HP ProBook 430 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                        This specification for the HP ProBook 430 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load, Asset Tag & Testntag boardview and 430 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                        HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                        This specification for the HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load, Asset Tag & Testntag boardview and 450 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
