Hi! My LG W3000h-bn switched to standby while working, and has been stuck in standby mode since, even after hard restarts. I've confirmed the computer, cables and mains are fine. The power button works but goes straight to amber standby light, the display never comes on.
I've opened up the unit and started testing the power supply. Visual inspection reveals nothing (caps look fine). With PS disconnected from all other boards, I only get 5V on the standby 5V and "ADC", a few mV on 6V and 12V outputs, and 0V on everything else. I noted that the standby 5V seems to oscillate, but only between 5.0 and 5.2V. With the board that has the video input connectors on it (what's that called?) plugged in, and the power/menu buttons plugged into that board so I could turn it on, I get:
ADC and ST5V: 5.07V (stable now)
6V: 6.6V, but seems to slowly drop over time, last measure a few minutes later was at 6.2V.
12V: 12.07V
19V: 17.8V, also seems to drop over time.
24V: 0V
3.4V: 0V
On/Off: 84mV
I-C: 84mV
Dim: 3.27V
Err: 0
I-B: 0
Bri: 0
Not sure what Bri, I-B, I-C, ADC are. I'm not too sure what to conclude with this. The monitor still stays in standby mode, so I'm guessing the 0's could be "normal". Is there a way to force it to turn on to test the voltages? I didn't find any "service manual" or such for this monitor.
Pics attached. Any help greatly appreciated!
12V: 12.07V
24V: 0V
3.4V: 0V
On/Off: 84mV
I-C: 84mV
Dim: 3.27V
Err: 0
I-B: 0
Bri: 0
