I repair arcade monitors, and as such have used the Mouser lists to order just what I need for a specific monitor at the click of a button.
When I went to order some today, I was told this:
This upsets me a bit as I've had really good luck with Xicon as a company. And I note that Lelon is on the "bad caps" list.
The Xicon series of Aluminum Electrolytic Capacitors are obsolete. These products will be replaced by product from Lelon Electronics Corporation. Most changes, if any, are cosmetic in nature (sleeve color, sleeve text, etc.).
Once stock has been depleted, this part will no longer be available. Mouser has added a suggested replacement for the original item. It is recommended that the specifications on both items be reviewed to assure the replacement part can be used in the application. 5-0210-14
