Hi everyone, I took upon a project, which is a stubborn Insignia NS-LCD32 that needs some professional attention. The story behind it is that the tv went through a thunderstorm and when the last owner tried to turn it would only show a green power light and nothing else.
Anyways here's the detailed rundown:
Pressing the power button makes power light go green, however the screen is blank and there is no sound even when I connect an HDMI device. Also to power the tv off and make the green power light disappear I have to hold the power button for approx 5 seconds.
Course of action:
First I checked the power supply and all voltage going out to the rest of the boards is correct so I'm pretty sure that its working fine.
Next I looked at the main board, however I'm not sure where to start and what to check on that. (I suspect there may be a problem with it because I believe it also controls the sound)
Then I moved on to the Inverter board. The one fuse that i found on it is fine, however the 5 of the 12 ballasts (not sure if i am using proper terminology, but the mini-transformer looking things) apparently were bad. At first I thought that this could be the root of all problems, since the sole function of an inverter board is to power up the bulbs, However there are no cables that go from the inverter board to the sound, so I am wondering if the main board might also have taken a hit. In addition to this I would like to know if there are a total of 6 outputs that power the screen and if say 2 end ones and 1 middle ballast/mini trasformer does not work, should the other bulbs light up, or do they follow a series circuit in which if one goes out, then all of them go out. If I was an engineer I would have made it easier to distinguish and put them in parallel so that if any one of the mini transformers failed, one light would go out, while the others would remain working.
Then on to the T Con board. I don't have a clue as to what to check on here, but i don't suspect it to be a problem because like i mentioned earlier there is no image, light, or sound, which means that the t con board might not be problematic.
This is the best I could do and I appreciate any advice or help and guidance that would help me ID the problem and fix this darn thing.
Thanks to all responses in advance
Course of action:
