Vizio E370VLE Standby/Logo flashing while on
    I could use some help with this. I'm working on a friend's Vizio E370VLE and the standby or vizio logo flashes orange and white at about 1 second intervals. The TV comes on, and it's been on for about 3 hours this morning. I've got picture and sound, basically it works fine but the logo keeps blinking. I've checked a few things but have yet to take any pictures of the boards. I'll post some pictures in a bit. Here's what I know.
    Main Board Voltage Regulators:1117 and 1117 1.2
    UP3
    1. 0.24v
    2. 1.47v
    3. 3.33v
    UP13 (adjustable)
    1. 0.00v
    2. 1.20v
    3. 3.33v
    UP14
    1. 2.04v
    2. 3.28v
    3. 5.24v
    Power Supply:
    Big Cap: 68uf 450v
    Voltage across: 388v
    Like I said, I've got picture and sound, for all intents and purposes, there doesn't seem to be anything wrong, just that the standby/logo light continues to alternate orange and white. No bulging caps, but I replaced most of them (ones I had replacements for) anyway on the power supply. Any ideas? This has me stumped!
    Last edited by DesertRat; 06-22-2015, 10:51 AM. Reason: added (help please) to title
    Re: Vizio E370VLE Standby/Logo flashing while on
    Here are pics of the PS front, back, and pins connection.
      Here is the Main board front and back, plus a shot with boards in place back of unit open.
        very unusual problem, this maybe a corrupt eeprom. I will try resetting the TV back to factory.
        I'm thinking resetting the TV could fix the problem or go from a working TV to not working TV.
          Thanks ecking767, I'm not sure if I want to possibly kill it. I was thinking black tape over the logo.
          I did find something though and I'm in the process of hopefully resolving the issue. In the photo attached is the connection for the standby/logo light. (Now, instead of black tape I have an option of just unplugging the light. Just kidding I'd like to see if we can figure this out). I found on the connection that the voltages are dropping. Starting from the top of the picture and going down the three connections read:
          1. 5.08v
          2. 2.78 ---drop to 1.92v then back to 2.78v
          3. 3.59 ---drop to 3.13v then back to 3.59V
          These are the voltages being sent to this connection from the main board. I just have to find from where they are being sent.
          From the close up picture you can see that I replaced UP3 but no changes in the voltages from the OP. I checked voltages on the PS on the 14 pin connection and they all read true to what they are supposed to be, and with no variations in voltages like on this connection.
            Ecking, by golly you were right! I got to looking into some things in the menu and found this in the System Information.
            Before Reset:
            Model: E370VLE
            Version: 0532
            Source Type: DTV
            Resolution: Unknown
            Vertical Freq.: 0
            Progressive: Unknown
            After Reset:
            Model: E370VLE
            Version: 0532
            Source Type: DTV
            Resolution: 704x480
            Vertical Freq.: 29.97
            Progressive: No
            It looks like it was a corrupt eeprom after all. Thanks for your help!
              So how did you get into reset mode on these E series?
                Go to the menu, then to 'Help' in that option you have a "Factory Defaults" reset option. You have to have the 4 digit Parental Code to reset, if you never assigned one then enter 0000, then 'yes'. It will restart and take you through the Setup Wizard. That's it! If the Parental Code has been set and forgotten, you may be out of luck. Oh, and you will need the remote since you have to enter the 4 digit code. You can use an app on a tablet or smart phone that has IR, as the remote. There is a free one on google play.
                  OK, I see, you did not have to get into the service menu mode using remote keys combination.
                    No, I was able to get into the menu using the buttons on the side, but had to get the remote before I could reset.
                      Straight from Vizio's website:
                      To restore a VIZIO TV to its factory default settings:
                      VIA TV
                      Press the MENU button on the remote.
                      In VIA it is: Depending on the model: Highlight HELP then Clear Memory. Or HELP then Reset and Admin and press the OK button then Clear Memory.
                      Use the Arrow buttons on the remote to highlight CLEAR MEMORY/FACTORY DEFAULTS or Reset TV to Factory Defaults and press the OK button.
                      Enter the parental control PIN (if you have never changed this, it is 0000) and press OK on the remote.
                      Do not press the Power button. The TV will reset, turn off, and then turn on again by itself.
                      The initial setup appears when the TV is powered back on. This is the same as the first time you turned on the TV.
                        Before Reset:
                        Model: E370VLE
                        Version: 0532
                        Source Type: DTV
                        Resolution: Unknown
                        Vertical Freq.: 0
                        After Reset:
                        Model: E370VLE
                        Version: 0532
                        Source Type: DTV
                        Resolution: 704x480
                        Progressive: No
                        Your welcome, glad it when in the right direction.
