Have a four year old HP s3700y w/Vista Home Premium SP2 found here: HP s3700y Support Doc. I know I should get a new computer with Win 7 or 8, but I happen to be one of those that really prefers the Vista OS vs. Win 7 that I'm using now on my laptop. This isn't a debate over OS's, just a problem with my current PC which I believe to be a hardware issue.
In another thread (http://tinyurl.com/966oacm) member @Gariarto raised issues about diagnostics and the like. Here I will be more specific.
Everything worked exceeding well until one day the system froze, including mouse, keyboard and of course the OS. I manually restarted the computer and everything was fine until it completely froze again. However, this time when I attempted to restart there was no power. So the first thing I did was replace the OEM PSU (160W) with a 250W PSU max wattage that will fit the case). The system started immediately, but once again froze after approx 10 minutes. At this time I figured it was the onboard graphics/chipset (nVidia GeForce 6150SE nForce 430) as each time the system froze the first thing to occur was the montor displaying a repeating series of colored lines (the color depended on the site I was currently on): I also noted that the heat sink was blistering hot, a hallmark of the nForce 430 chipset.
I consulted other forums and all agreed the onboard video needing replacing. Replaced with a PCI-e nVidia 8400 card with fan. all worked well for 24 hours then the system once again froze. I checked the Event Viewer at the exact times the freeze-ups occurred and NO errors were reported. Because of this I ran every diagnostic test that I knew of or that was recommended. These included memtest86, HP's diagnostic tool, chkdsk, Furmark, SpeedFan for temps, ran the HD utlility from Seagate and no bad sectors, etc. As a last resort I formatted the disk and installed a fresh copy of Vista. I only installed Firefox and the system froze again within an hour. At this point I just accepted the fact that the onboard nVidia chipset was damaged and that the prudent thing to do was to purchase new PC.
After posting a question at bleepingcomputer.com and then referred here re: the heat sink being scalding hot when the onboard video was disabled in BIOS and potential capacitor damage.
So that's where it stands to date and it's just a case of potentially throwing money away on a new mobo for this Min--ITX or just purchase a more heat-friendly PC. If someone has any potential solutions other than the above I'd love to hear them. The real problem is that I have enjoyed the s3700y with Vista and if salvageable that would be fantastic.
Thanks for the long read and any info that you wish to provide.
