Plug the set in and you get the amber logo then turn on with remote or button on side logo turns white screen comes on with vizio logo then shows the selected input for a couple seconds and shuts off. For a couple tries when i first plug it in it may stay on for a couple minutes and then you'll get picture then after another minute or 2 sound and eventually off. During the on time any functions were delayed by 5 to 10 seconds. You could hit menu then 5 to 10 seconds later it would come up down arrow then to 10 seconds the menu would move down one slot hit ok then 10 seconds later next sub menu would come up etc. Eventually it got to where it is now boots up and shuts off within a few seconds. Power supply seems fine from what i read and checked as do the voltage regulators, i bought the repair kit from ebae and once i saw what they gave me i tested those 2 fuses and regulators which are good so didnt change anything on the board yet.
Vizio m550sv shutting off after boot up
Re: Vizio m550sv shutting off after boot up
Those Voltages and the signals are OK.
Need to check the LED driver board (the Green sub board on the power supply) to see what you have on the LED connectors. Need closed up pictures of the LED connector and the whole back side of the TV so we can see how all the boards are connected together.
This board looks like the board you have, please verify.
http://www.shopjimmy.com/vizio-0500-...-led-board.htm
Delta DPS-216CPLast edited by budm; 11-02-2016, 09:57 PM.Never stop learning
Post #6
"Need closed up pictures of the LED connector and the whole back side of the TV so we can see how all the boards are connected together."Never stop learning
Sorry, I see all the board now.
https://www.badcaps.net/forum/attach...3&d=1478147261
So the connector on the LED driver green board that goes to the main board will be where the control signals for the backlights are, then the two white connectors CN302, CN303 with the wires going inside the panel will be where you need to test the LED Voltages (FB1~16 with ref to chassis GND) for each string of the LED, it has 16 strings of LEDs. You will have to turn the TV off, put red probe on FB1 then urn on the TV and take the DCV reading, record that reading, then turn the TV off and then repeat the same procedure for FB 2~16.
Pictures provided by shopjimmy.Last edited by budm; 11-03-2016, 02:10 PM.Never stop learning
Tried to take a video of what it does.
https://youtu.be/4i4rFgRM9sY
I got the input changed from rgb to hdmi and now it will stay on longer sometimes for 30 sec sometimes up to 5 minutes sometimes audio will come on after 45 seconds then video a bit later sometimes not. All functions are delayed like the processor is overworked or ram is filled up menu functions are delayed by 3 to 20 seconds per button push.
I am fairly sure there is no one capable of figuring this TV out I have replaced everything with new parts in mine except for my Timing control board I am about ready to order that and if it doesn't work I may just make a video of me bashing it in with a baseball bat and post it on youtube and see how many hits I get for the heck of it.
I could have had a couple of decent tv's with the money I spent on this thing.
TVPlease note: I am not responsible for any harm caused to you anything discussed is just discussion. Before you try anything discussed be sure that you have the appropriate knowledge and safety gear for the job. Like with anything education and safety are first! Do not try anything @ home without it.
