The patient is a Sceptre X9G NagaV monitor that does not power on. This monitor is a 19" flat panel with CCFL back lighting. It has both DVI and VGA inputs. Before even opening the monitor I suspect bad caps on the power board.
After opening the back off the monitor I was surprised to see the layout. Instead of a video board on the right side, the DVI and VGA connectors were cables running to the video board under a metal plate. Just a different design from the typical.
Focusing on the power/inverter board, I immediately see two bulging caps. The bulging caps were 1000uF/16V. Even though I have an ESR meter, I decided to just replace all caps on the power/inverter board. The full list of caps on the power/inverter board:
1000uF/16V (2x)
470uF/35V (2x)
220uF/25V (5x)
10uF/50V (1x)
I replaced all the caps with Panasonic FM and FC series caps. The board was very easy to work with. Desoldering the caps was very easy. After replacing the caps and putting the monitor back together it powers up just fine.
1000uF/16V (2x)
470uF/35V (2x)
220uF/25V (5x)
10uF/50V (1x)
